How to use processor expert for MC9S12DG128CPVE microcontroller
4,940件の閲覧回数
arunrajk
Fresh Out Contributor
I am using freescale MC9S12DG128CPVE microcontroller for my project. But the processor expert not cpu architecture for that particular microcontroller. How i use the processor expert for above mentioned microcontroller.
4,583件の閲覧回数
Hello Arunraj K,
You can try to install the Processor Expert update , while I haven't test it .
If it can't work, I think you can choose CW5.1.
About download the PE update , please go to the CW5.2 download site, then choose "Previous " button,
select 5.1,
https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=5901341
then :
Hope it helps
TIC
7 返答(返信)
4,583件の閲覧回数
Hi Arunraj K,
It is my pleasure.
Alice
4,583件の閲覧回数
arunrajk
Hi Alice,
   I installed CW version 5.2. same what is mentioned in the given link. After that i will get the controller package in CW but not in the Processor expert. That is the problem what i am facing now. please help me to solve the issue.
4,584件の閲覧回数
Hello Arunraj K,
select 5.1,
then :
Hope it helps
TIC
4,583件の閲覧回数
arunrajk
Hi Alice,
Now the issue solved. Thanks Alice for the support.
Have a good day,
Arunraj k
4,583件の閲覧回数
Hello Arunraj K,
You can use the cpu component  as below :
please have a look at the part number meaning :
Hope it helps
TIC
4,583件の閲覧回数
arunrajk
Hi yang,
Thanks for the reply. I think my way of questioning is wrong. My problem is that mentioned CPU is not found in the processor expert menu. what can i do for getting that particular cpu in my processor expert menu?
My Processor expert menu screen short is given in below,
When i creating the project the error was like in below image,
4,583件の閲覧回数
Hello Arunraj,
Which version of CW do you used ?
5.1 ? Please check have you install the update .
5.2? Please check this thread :
https://community.nxp.com/message/908307
Alice
