How to select external Oscillator using processor expert in S32DS project
2,932 次查看
kashifsagheer
I am new on the processor expert and NXP 32bit MCUs. I want to select only the external oscillator in the clock setting.
  • How can I configure the external oscillator and then PLL
  • system clock should also be based on SOSC
  • Bus clock is also drive from SOSC
How can I verify#@ whether I select correct clock or not?
2,792 次查看
Alexis_A
Hello kashifsagheer‌,
To enable/disable the clocks there's a little checkbox in the Clock Sources table:
In the Interface Clocks table you can select the clock source if you click in the SCS_CLK option:
If you change the SCS_CLK the BUS_CLK will have the same clock source.
Also in the Clock configuration table, if you click in the tab, more configuration options will be displayed:
Let me know if this helps you.
Alexis Andalon
2,792 次查看
kashifsagheer
Hello Alexis,
Thank you!
