Help on Component
Help on Component
1,612件の閲覧回数
ERussell
I am trying to start a project for the K64 processor using Eclipse(Juno 4.2.2/Kepler) with the IAR plugin and the PE 10.4.1 plugin. Every time I select the PE menu item "Help on Component" Eclipse quits. Any suggestions?
Elizabeth
1,490件の閲覧回数
ZhangJennie
hello Elizabeth,
I never had this problem. I wonder the problem is due to software install or any other software(for example firewall?) prevent help working.
i suggest you uninstall your software then reinstall them with windows admin right.
during install, please close all the firewall and virus defenders.
then test same again.
this answer is for you, if it helps, please click on "correct answer " button. thanks!
ZhangJun
1,490件の閲覧回数
ERussell
Unfortunately, reinstalling without a firewall did not change the result. Thanks for the suggestion.
Elizabeth
