DPDK unable to list DPAA network interface in LS1043ARDB
1,187 次查看
bhargavjayswal
Hi NXP Team,
I have build kernel (linux-qoriq - kenel version 6.1) and core-minimal-rootfs for ls1043ARDB using yocto base layerscape SDK and also enabled FMC and dpdk packages. I had refere Layerscape_Linux_distribution_POC_user_guide (LLDPU0G_RevL6.1.1_1.0.0_23.08.pdf) for setup and cross-compilation process.
LS1043ARDB has been boot with conf-freescale_fsl-ls1043a-rdb-sdk.dtb and conf-freescale_fsl-ls1043a-rdb-usdpaa.dtb, but in both case, i can't see network interfaces list in "dpdk-devbind.py -s" command. Could you please provide debug steps and how to resolve it.
Here I have attached log for your reference.
Bhargav Jayswal
1,117 次查看
yipingwang
Please run the following command in build environment.
$ bitbake fsl-image-networking
Boot Linux with commands
=> tftp 0xa0000000 b25805/ls1043ardb/Image
=> tftp 0xb0000000 b25805/ls1043ardb/ fsl-image-networking-ls1043ardb.cpio.gz.u-boot
=> tftp 0xc0000000 b25805/ls1043ardb/fsl-ls1043a-rdb-usdpaa.dtb
=> booti 0xa0000000 0xb0000000 0xc0000000
