DMA trig
DMA trig
1,797 次查看
AsafTv
I have configure ADC to work with DMA. the ADC is Triggered by timer 1.
the ADC should sample several channel so I added to my hardware Multiplexer . the multiplexer driven by DMA buffer to port. the buffer is contains the port state for the multiplexer. I want that the DMA of The port will triggered by ADC end of conversion. can I do it?
1,781 次查看
PabloAvalos
Hi @AsafTv
Thank you so much for your patience and hope you are well.
Appreciating that you reached our customer support in our community, I would like to help you with all the questions that you have, but I see that you opened a similar case today about a similar concern, so I will be handling both questions on the most recent thread of our community (https://community.nxp.com/t5/MCUXpresso-SDK/ADC-sequential-conversion/td-p/1404556), if it is ok for you.
Please let me know if you have more questions.
Thank you.
Sincerely,
Pablo Avalos.
标记 (1)
