MCC33816 Studio Compile Fail
2,445件の閲覧回数
rmaier
I am not able to build my project. Can you please direct me in the right direct to fix this?
Here is the build output:
Starting build...
Deleting previous output files
Launching Assembler
Java RUNTIME version used for PSC microcode is : 11.0.16.1
Java BUILD version used for PSC microcode is : 1.6.0_18
FATAL [21-08 16:39:16]: Unexpected error. Please report with maximum context information - com.freescale.mc33816.assembler.Assembler.handleArgsAndRun (Assembler.java:169)
FATAL [21-08 16:39:16]: Throwable:javax/xml/bind/JAXBException - com.freescale.mc33816.assembler.Assembler.handleArgsAndRun (Assembler.java:170)
FATAL [21-08 16:39:16]: com.freescale.mc33816.assembler.Assembler.<init>(Assembler.java:73)
com.freescale.mc33816.assembler.Assembler.handleArgsAndRun(Assembler.java:157)
com.freescale.mc33816.assembler.Assembler.nonExitingMain(Assembler.java:131)
com.freescale.mc33816.assembler.Assembler.main(Assembler.java:112)
java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.base/java.lang.reflect.Method.invoke(Method.java:566)
com.simontuffs.onejar.Boot.run(Boot.java:306)
- com.freescale.mc33816.assembler.Assembler.handleArgsAndRun (Assembler.java:171)
Log write Failed.
Launching Assembler
Log write Failed.
Successfully created SPIGen load file
3 返答(返信)
2,422件の閲覧回数
JozefKozon
Hello Robert,
could you please share more information? I presume you are using our MC33816 Developer Studio IDE right? Are you using one of our EVBs? KIT33816AEEVM or KIT33816FRDMEVM? If you are using your own design please share your schematic with voltage levels and part values. Are you aware of this document? https://www.nxp.com/docs/en/user-guide/MC33816ASM_APPSPUG.pdf
And other documents and videos on the MC33816 product page?
With Best Regards,
Jozef
2,375件の閲覧回数
rmaier
I managed to get it to work after scouring the web for how to redirect to the right version of JAVA. I couldn't tell you what exact procedure got it to work, but the IDE is now getting the desired java version.
2,363件の閲覧回数
JozefKozon
Hello Robert,
great. I am glad you have successfully made the IDE run. Thank you for posting it here.
With Best Regards,
Jozef
