About MC33816 Vboost
5,713 次查看
1334769096
I used the MC33816 IDE build the code for MC33816, but however I changed the Vboost voltage, from 24V to 65V. The Vboost always up to almost 80V, then the chip be broken. The mean is I can't control it. Can you help me?
Thanks!
7 回复数
5,596 次查看
zflailfh
I also encountered the same problem, I can't control the Vboost,so I had to use a voltage regulator to protect the MC33816 from damage。
Does anyone know of a solution to this problem?
5,596 次查看
1334769096
Yep! I resolved it
5,596 次查看
zflailfh
How did you solve it? (=^ ^=)
5,596 次查看
1334769096
Other configurations is default, The MC33816 IDE version is 2.3.1.0
5,596 次查看
guoweisun
Which kind of board do you test on? EVB or your own design board?
5,596 次查看
1334769096
my own design board, The schematic refers to the official demo.  And I wanna know If I used the default configurations on MC33816 IDE, Can I direct to test the board?
5,596 次查看
guoweisun
Suggest you test in EVB firstly,even if the default setting the Vboost can't up to 80V because of the maximum value is about 72V.
