MC33816
MC33816
HALO
HI
Does the IRQB pin of MC33816 need to be connected to a pull-up resistor? I did not find the hardware circuit about IRQB pin in the data sheet
thanks
guoweisun
You can directly use it as output without pull up!
guoweisun
In your application, does IRQB configurate as input or output?
HALO
HI IRQB configurate as output. Thanks
HALO
