syntax error at line one
1,193件の閲覧回数
maheshwarreddy
we are using the code warrior  v8.8 in that while entering into debug that time we are getting an error .tha errors ccs log will be attached below .
Thank you
Maheshwar reddy.
タグ(2)
1,091件の閲覧回数
Pavel
Test your connection of your TAP to the board.
Use /Tools/Hardware Diagnostics menu of CodeWarrior 8.8.
The MPC866 uses BDM connection (10pins) for debugging.
Pavel Chubakov
