codewarrior v8.8
codewarrior v8.8
1,716 次查看
venkat1
Hi all,
I am working on MPC8358 Power architecture processor using Codewarrior v8.8 IDE. while configuring init file in Codewarrior setup window but  its not updating in .asm or in any related file.
please tell me what would be the problem for this?
Venkat
1,708 次查看
yipingwang
For MPC8358 custom board bring up, you need to modify initialization file  PowerPC_EABI_Support\Initialization_Files\PQ2\8360MDS_rev1_init.cfg based on your target board.
Please create a bareboard project for MPC8358 in CodeWarrior IDE, in "Select processor and board" panel, please select processor PowerPC 8358 and board 8360MDS(rev1).
Then modify initialization file in CodeWarrior IDE from Edit->Debug Version Settings->Debugger->EPPC Debugger Settings->Use Target Initialization File.
1,691 次查看
venkat1
sir, I have followed the above process but the .cfg file is not updating into the project code.
please tell me, what will be the problem?
