Thanks for replying to my question. I think what you mean is that P1020 does not support MCC by hardware. Yes, I am running UMCC through UCC, more specifically UCC1.
When I use 32 channels, I only setup 32 SI RAM entries, 32 MU RAM routing entries, 32 channel extra parameter entries and 32 channel specific parameters entries. In this case, everything works perfectly.
If I just change 32 to 64, none of the channels really starts. I can see that from the channel specific parameters. If a channel comes up, the QUICC engine micro code will load the parameters with new values instead of the configured values. As for the UCCE, the value is always zero when no channel is running.
The following are the memory/register dumps regarding the configurations.
// UCC1 Registers
E0082000: 00040032 00001F82-00000000 00007E7E ...2..........~~
E0082010: 00000000 FF0F0000-00000000 00000000 ................
E0082020: 00000000 00800000-0040FFFF 00000000 .........@......
E0082030: 00800000 00400000-00200000 01000000 .....@... ......
E0082040: 00000000 80000C08-80000000 00000000 ................
E0082050: 00000000 00000000-00000008 00000000 ................
E0082060: 00000000 00000000-00000000 00000000 ................
E0082070: 00000000 00000000-00000000 00000000 ................
E0082080: 00000000 00000000-00000000 00000000 ................
E0082090: 10000000 00000000-00000000 00000000 ................
E00820A0: 00000000 00000000-00000000 00000000 ................
// UCC1 Global Parameters
E0094000: 1A16B2C0 00000400-00010001 00000000 ................
E0094010: 00000000 00000000-1A25B2C0 1A25B2C0 .........%...%..
E0094020: 00000000 00000000-DEBB20E3 5100F0B8 .......... .Q...
E0094030: 00000000 00000000-00000000 00000000 ................
E0094040: 1A22B2C0 1A22B2C0-00000000 00000000 ."..."..........
E0094050: 00000000 00000000-00000000 00000000 ................
E0094060: 00000000 00000000-00000000 00000000 ................
E0094070: 00000000 00000000-00000000 00000000 ................
E0094080: 00000000 00000000-00000000 00000000 ................
E0094090: 00000000 00000000-00000000 00000000 ................
E00940A0: 00004CFE 00004D50-0000001F 00000287 ..L...MP........
E00940B0: 7E7E0FC1 00000000-00004400 00000000 ~~........D.....
E00940C0: 00004AFE 00004B3E-00000000 00000000 ..J...K>........
E00940D0: 00000000 00004600-00000000 00000000 ......F.........
E00940E0: 00000000 00000000-00000000 00000000 ................
E00940F0: 00000000 00000000-00000000 00000000 ................
// Channel Specific Parameters
// Using channel 0-5, HDLC/HDLC/TRANS/TRANS/HDLC/HDLC
E0090000: 10800000 00000207-7E7E7E7E 7E7E7E7E ........~~~~~~~~
E0090010: 00000000 00000000-031FE000 0000FFFF ................
E0090020: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E0090030: 00000000 00000000-40000000 00000000 ........@.......
E0090040: 10800000 00000207-7E7E7E7E 7E7E7E7E ........~~~~~~~~
E0090050: 00000000 00000000-031FE000 0000FFFF ................
E0090060: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E0090070: 00000000 00000000-40000000 00000000 ........@.......
E0090080: 10800000 10000207-FFFFFFFF FFFFFFFF ................
E0090090: 00000000 00000000-031F7000 0000FFFF ..........p.....
E00900A0: 10800000 50FFFFE0-FFFFFFFF 8000FFFF ....P...........
E00900B0: 00000000 00000000-00600000 00000000 .........`......
E00900C0: 10800000 10000207-FFFFFFFF FFFFFFFF ................
E00900D0: 00000000 00000000-031F7000 0000FFFF ..........p.....
E00900E0: 10800000 50FFFFE0-FFFFFFFF 8000FFFF ....P...........
E00900F0: 00000000 00000000-00600000 00000000 .........`......
E0090100: 10800000 00000207-7E7E7E7E 7E7E7E7E ........~~~~~~~~
E0090110: 00000000 00000000-031FE000 0000FFFF ................
E0090120: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E0090130: 00000000 00000000-40000000 00000000 ........@.......
E0090140: 10800000 00000207-7E7E7E7E 7E7E7E7E ........~~~~~~~~
E0090150: 00000000 00000000-031FE000 0000FFFF ................
E0090160: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E0090170: 00000000 00000000-40000000 00000000 ........@.......
E0090180: 100005B0 002FCFC4-7E7E7E7E 7E7E7E7E ...../..~~~~~~~~
E0090190: 00000000 00000000-0000A000 0000FFFF ................
E00901A0: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E00901B0: 00000000 00000000-40000000 00000000 ........@.......
E00901C0: 100005B0 002FCFC4-7E7E7E7E 7E7E7E7E ...../..~~~~~~~~
E00901D0: 00000000 00000000-0000A000 0000FFFF ................
E00901E0: 10800000 00FFFFE0-FFFFFFFF 8000FFFF ................
E00901F0: 00000000 00000000-40000000 00000000 ........@.......
// Channel Extra Parameters
E0095100: 0000 0000 C000 C000-00C0 00C0 C0C0 C0C0 ................
E0095110: 0180 0180 C180 C180-0240 0240 C240 C240 .........@.@.@.@
E0095120: 0300 0300 C300 C300-03C0 03C0 C3C0 C3C0 ................
E0095130: 0480 0480 C480 C480-0540 0540 C540 C540 .........@.@.@.@
E0095140: 0600 0600 C600 C600-06C0 06C0 C6C0 C6C0 ................
E0095150: 0780 0780 C780 C780-0840 0840 C840 C840 .........@.@.@.@
E0095160: 0900 0900 C900 C900-09C0 09C0 C9C0 C9C0 ................
E0095170: 0A80 0A80 CA80 CA80-0B40 0B40 CB40 CB40 .........@.@.@.@
E0095180: 0C00 0C00 CC00 CC00-0CC0 0CC0 CCC0 CCC0 ................
E0095190: 0D80 0D80 CD80 CD80-0E40 0E40 CE40 CE40 .........@.@.@.@
E00951A0: 0F00 0F00 CF00 CF00-0FC0 0FC0 CFC0 CFC0 ................
E00951B0: 1080 1080 D080 D080-1140 1140 D140 D140 .........@.@.@.@
E00951C0: 1200 1200 D200 D200-12C0 12C0 D2C0 D2C0 ................
E00951D0: 1380 1380 D380 D380-1440 1440 D440 D440 .........@.@.@.@
E00951E0: 1500 1500 D500 D500-15C0 15C0 D5C0 D5C0 ................
E00951F0: 1680 1680 D680 D680-1740 1740 D740 D740 .........@.@.@.@
E0095200: 1800 1800 D800 D800-18C0 18C0 D8C0 D8C0 ................
E0095210: 1980 1980 D980 D980-1A40 1A40 DA40 DA40 .........@.@.@.@
E0095220: 1B00 1B00 DB00 DB00-1BC0 1BC0 DBC0 DBC0 ................
E0095230: 1C80 1C80 DC80 DC80-1D40 1D40 DD40 DD40 .........@.@.@.@
E0095240: 1E00 1E00 DE00 DE00-1EC0 1EC0 DEC0 DEC0 ................
E0095250: 1F80 1F80 DF80 DF80-2040 2040 E040 E040 ........ @ @.@.@@
E0095260: 2100 2100 E100 E100-21C0 21C0 E1C0 E1C0 !.!.....!.!.....
E0095270: 2280 2280 E280 E280-2340 2340 E340 E340 ".".....#@#@.@.@
E0095280: 2400 2400 E400 E400-24C0 24C0 E4C0 E4C0 $.$.....$.$.....
E0095290: 2580 2580 E580 E580-2640 2640 E640 E640 %.%.....&@&@.@.@
E00952A0: 2700 2700 E700 E700-27C0 27C0 E7C0 E7C0 '.'.....'.'.....
E00952B0: 2880 2880 E880 E880-2940 2940 E940 E940 (.(.....)@)@.@.@
E00952C0: 2A00 2A00 EA00 EA00-2AC0 2AC0 EAC0 EAC0 *.*.....*.*.....
E00952D0: 2B80 2B80 EB80 EB80-2C40 2C40 EC40 EC40 +.+.....,@,@.@.@
E00952E0: 2D00 2D00 ED00 ED00-2DC0 2DC0 EDC0 EDC0 -.-.....-.-.....
E00952F0: 2E80 2E80 EE80 EE80-2F40 2F40 EF40 EF40 ......../@/@.@.@
// SI Routing Entries
// TX Routing
E0081000: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081010: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081020: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081030: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081040: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081050: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081060: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081070: 013C 013C 013C 013C-013C 013C 013C 013D .<.<.<.<.<.<.<.=
// RX Routing
E0081400: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081410: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081420: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081430: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081440: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081450: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081460: 013C 013C 013C 013C-013C 013C 013C 013C .<.<.<.<.<.<.<.<
E0081470: 013C 013C 013C 013C-013C 013C 013C 013D .<.<.<.<.<.<.<.=
// MU RAM Routing Entries
// Rx Routing
E0094B00: 0007 0017 0027 0037-0047 0057 0067 0077 .....'.7.G.W.g.w
E0094B10: 0087 0097 00A7 00B7-00C7 00D7 00E7 00F7 ................
E0094B20: 0107 0117 0127 0137-0147 0157 0167 0177 .....'.7.G.W.g.w
E0094B30: 0187 0197 01A7 01B7-01C7 01D7 01E7 01F7 ................
E0094B40: 0207 0217 0227 0237-0247 0257 0267 0277 .....'.7.G.W.g.w
E0094B50: 0287 0297 02A7 02B7-02C7 02D7 02E7 02F7 ................
E0094B60: 0307 0317 0327 0337-0347 0357 0367 0377 .....'.7.G.W.g.w
E0094B70: 0387 0397 03A7 03B7-03C7 03D7 03E7 83F7 ................
// Tx Routing
E0094D00: 0007 0017 0027 0037-0047 0057 0067 0077 .....'.7.G.W.g.w
E0094D10: 0087 0097 00A7 00B7-00C7 00D7 00E7 00F7 ................
E0094D20: 0107 0117 0127 0137-0147 0157 0167 0177 .....'.7.G.W.g.w
E0094D30: 0187 0197 01A7 01B7-01C7 01D7 01E7 01F7 ................
E0094D40: 0207 0217 0227 0237-0247 0257 0267 0277 .....'.7.G.W.g.w
E0094D50: 0287 0297 02A7 02B7-02C7 02D7 02E7 02F7 ................
E0094D60: 0307 0317 0327 0337-0347 0357 0367 0377 .....'.7.G.W.g.w
E0094D70: 0387 0397 03A7 03B7-03C7 03D7 03E7 83F7 ................
XL
