DDR3 ECC Memory Connection
14,140 次查看
aleksandrmaskin
Hello!
I've already written in Technical Support, but surely I get here a sooner answer. I've just started a new MPC8569E project. By the way, I had never dealt with Freescale processors before. I chose Micron 8-bit DDR3 memory to be EEC. It found out that it has a combined data mask and termination data strobe ball. How can I connect it to the DDR controller? Is it possible at all?
Thanks.
标记 (1)
24 回复数
1,055 次查看
aleksandrmaskin
Hi, I found nothing concerning that their.
Maybe, I can make it without DM-signal in ECC?:smileyconfused:
1,055 次查看
lunminliang
HI, could you please send out the URL of the datasheet?
1,055 次查看
aleksandrmaskin
OK. I can send you datasheets in about a week.
1,055 次查看
aleksandrmaskin
I uploaded the datasheet into my docs section. Hope, you can find it.
