Code-Worrier programming corruption with NOR flash in T2080RDB
2,696 次查看
singhawadhesh
Hi Team,
I was experimenting with NOR of T2080RDB and I have flashed U-boot with code-worrier in alternate bank of it. After making dump of that, I have compared it with actual file loaded into it with beyond compare (after converting both into HEX). I am finding there is mismatch in the dump data and the loaded file and unable to boot completely. When I am checking those locations (0xEBF4A19C) in memory window of debug, I am getting 0x4C00018C at every corrupted locations.
Please let me know the possible issue.
Thanks for your support.
Awadhesh
2,679 次查看
yipingwang
Please upgrade to CodeWarrior 10.5.2 to check whether this problem could be resolved.
Please open CodeWarrior IDE, please click Help->Install New Software->Available Software Sites, please select "CodeWarrior Power Architecture v10.5.2 Release, click drop down list at "Work with", then select "CodeWarrior Power Architecture v10.5.2 Release - http://freescale.com/lgfiles/updates/Eclipse/PA10_5_1/com.freescale.pa.updatesite_win/COMPILER", then install CodeWarrior 10.5.2 step by step.
2,680 次查看
yipingwang
