CPU mpc8315e hangs if I touch its top surface
zhenhuan
what  is possible reason?
alexander_yakov
The most probable reason - some input pin may be left unconnected and acts as antenna.
alexander_yakov
zhenhuan
It turned out that  TEST_MODE pin (D6) was left unconnected, it shold be the reason.
LPP
Also, it migh be a failed joint under the package that bounces under the pressure. You can distinguish between two reasons by touching the package by a plastic stick rather than by a finger.
