wireless_power
wireless_power
sltaief
Hello, Which wireless powers ICs are certified the Qi1.3?
guoweisun
sltaief
Can you please answer me?
sltaief
The MWCT2xx3A can be used for automotive, industry and consumer. I see this form its datasheet.
I have another question Is there an example schematic (eval board) ?
sltaief
The MWCT2xx3A is used for the automotive application. Can I use it for another application (e.g Industry, consumer ...) ?
guoweisun
No problem.
guoweisun
suggest to select WCT2013
sltaief
Can you please confirm?
sltaief
Example from this list https://www.nxp.com/products/power-management/wireless-power:WIRCHA_ICS
Datasheet of MWCT1x1x
  • Compliant with the latest Wireless Power Consortium (WPC) specification
    Does this means Qi1.3?
guoweisun
All of us wireless charge partS support this QI1.3.
sltaief
1- There is only a solution for the automotive application, right?
2- From this list https://www.nxp.com/products/power-management/wireless-power:WIRCHA_ICS
there is no IC certified qi1.3, right?
guoweisun
