fs23 Lin mode swith question
2,422件の閲覧回数
gumu
We encountered a question while debugging the FS LIN functionality. Specifically, we found that in debug mode, we cannot set the LINTRCV_FS23_TRCVMODE_OFF mode using the LinTrcv_fs23_SetMode() function.
The code snippet is as follows:
Std_ReturnType LinTrcv_fs23_SetMode(uint8 u8LinNetwork, LinTrcv_fs23_TrcvModeType eOpMode)
    uint16 u16RegData = 0U;
    Std_ReturnType eStatus;
    LinTrcv_fs23_TrcvModeType eNewHwOpMode = LINTRCV_FS23_TRCVMODE_INVALID;
    /* Read M_LIN register. */
    eStatus = Sbc_fs23_ReadRegister(SBC_FS23_M_LIN_ADDR, &u16RegData);
    if ((Std_ReturnType)E_OK == eStatus)
        /* Set new register value. */
        u16RegData &= ~(SBC_FS23_M_LIN_MODE_MASK | SBC_FS23_M_LIN_SLOPE_MASK| SBC_FS23_M_LIN_FS_DIS_MASK);
        if(TRUE == xG_drivers[u8LinNetwork].bLinSlowSlope)
            u16RegData |= SBC_FS23_M_LIN_SLOPE_SLOW;
        if(FALSE == xG_drivers[u8LinNetwork].bLinFailsafeDisable)
            u16RegData |= SBC_FS23_M_LIN_FS_DIS_KEEP;
        u16RegData |= ((uint16)eOpMode << SBC_FS23_M_LIN_MODE_SHIFT);
        eStatus = Sbc_fs23_WriteRegister(SBC_FS23_M_LIN_ADDR, u16RegData);
        /*Check the real hardware state*/
        eStatus |= LinTrcv_fs23_GetMode(u8LinNetwork, &eNewHwOpMode);
        if((eNewHwOpMode == eOpMode) && ((Std_ReturnType)E_OK == eStatus))
            eStatus = (Std_ReturnType)E_OK;
        else
            eStatus = (Std_ReturnType)E_NOT_OK;
    return eStatus;
The eOpMode is LINTRCV_FS23_TRCVMODE_OFF,  the eNewHwOpMode  is LINTRCV_FS23_TRCVMODE_NORMAL.
The manual states that in debug mode, LIN defaults to active mode. Is this behavior normal?
Thanks!
2,391件の閲覧回数
quangvuanh
Hi @gumu , I got confirmation from hardware team that it's a normal behaviour. In debug mode, the transceiver mode is forced ACTIVE. So even if you try and change the LIN_MODE field to OFFLINE (OFF, 2b00) then the transceiver stays in active mode.
3 返答(返信)
2,393件の閲覧回数
quangvuanh
Hi, I have to check with hardware team. Can you please let me know what version of FS23 that you have? Or what is the part number?
2,392件の閲覧回数
quangvuanh
2,408件の閲覧回数
TomasVaverka
Hi Quang (@quangvuanh),
Could you please help with this question from Anhui Zhitu Technology China?
Thanks & BRs, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-1993707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efs23%20Lin%E3%83%A2%E3%83%BC%E3%83%89swith%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3CSPAN%3EFS%20LIN%E6%A9%9F%E8%83%BD%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AB%E8%B3%AA%E5%95%8F%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%3C%2FSPAN%3ELinTrcv_fs23_SetMode()%20%E9%96%A2%E6%95%B0%3CSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6LINTRCV_FS23_TRCVMODE_OFF%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%20%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EStd_ReturnType%20LinTrcv_fs23_SetMode(uint8%20u8LinNetwork%2C%20LinTrcv_fs23_TrcvModeType%20eOpMode)%0A%7B%0A%20%20%20%20uint16%20u16RegData%20%3D%200U%3B%0A%20%20%20%20Std_ReturnType%20eStatus%3B%0A%20%20%20%20LinTrcv_fs23_TrcvModeType%20eNewHwOpMode%20%3D%20LINTRCV_FS23_TRCVMODE_INVALID%3B%0A%20%20%20%20%2F*%20Read%20M_LIN%20register.%20*%2F%0A%20%20%20%20eStatus%20%3D%20Sbc_fs23_ReadRegister(SBC_FS23_M_LIN_ADDR%2C%20%26amp%3Bu16RegData)%3B%0A%0A%20%20%20%20if%20((Std_ReturnType)E_OK%20%3D%3D%20eStatus)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%2F*%20Set%20new%20register%20value.%20*%2F%0A%20%20%20%20%20%20%20%20u16RegData%20%26amp%3B%3D%20~(SBC_FS23_M_LIN_MODE_MASK%20%7C%20SBC_FS23_M_LIN_SLOPE_MASK%7C%20SBC_FS23_M_LIN_FS_DIS_MASK)%3B%0A%20%20%20%20%20%20%20%20if(TRUE%20%3D%3D%20xG_drivers%5Bu8LinNetwork%5D.bLinSlowSlope)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20u16RegData%20%7C%3D%20SBC_FS23_M_LIN_SLOPE_SLOW%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20if(FALSE%20%3D%3D%20xG_drivers%5Bu8LinNetwork%5D.bLinFailsafeDisable)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20u16RegData%20%7C%3D%20SBC_FS23_M_LIN_FS_DIS_KEEP%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20u16RegData%20%7C%3D%20((uint16)eOpMode%20%26lt%3B%26lt%3B%20SBC_FS23_M_LIN_MODE_SHIFT)%3B%0A%0A%20%20%20%20%20%20%20%20eStatus%20%3D%20Sbc_fs23_WriteRegister(SBC_FS23_M_LIN_ADDR%2C%20u16RegData)%3B%0A....%0A%20%20%20%20%20%20%20%20%2F*Check%20the%20real%20hardware%20state*%2F%0A%20%20%20%20%20%20%20%20eStatus%20%7C%3D%20LinTrcv_fs23_GetMode(u8LinNetwork%2C%20%26amp%3BeNewHwOpMode)%3B%0A%20%20%20%20%20%20%20%20if((eNewHwOpMode%20%3D%3D%20eOpMode)%20%26amp%3B%26amp%3B%20((Std_ReturnType)E_OK%20%3D%3D%20eStatus))%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20eStatus%20%3D%20(Std_ReturnType)E_OK%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20eStatus%20%3D%20(Std_ReturnType)E_NOT_OK%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%0A%20%20%20%20return%20eStatus%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EeOpMode%E3%81%AFLINTRCV_FS23_TRCVMODE_OFF%E3%80%81eNewHwOpMode%E3%81%AFLINTRCV_FS23_TRCVMODE_NORMAL%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81LIN%20%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1994564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Afs23%E3%83%AA%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89swith%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1994564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211858%22%20target%3D%22_blank%22%3E%40gumu%3C%2FA%3E%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%9D%E3%82%8C%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AA%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E7%A2%BA%E8%AA%8D%E3%82%92%E5%8F%97%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%20data-teams%3D%22true%22%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81LIN_MODE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92OFFLINE(OFF%E3%80%812b00)%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%81%AF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1994550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Afs23%E3%83%AA%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89swith%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1994550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BFS23%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Afs23%E3%83%AA%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89swith%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Quang%20(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220202%22%20target%3D%22_blank%22%3E%40quangvuanh%3C%2FA%3E)%2C%3C%2FP%3E%0A%3CP%3EAnhui%20Zhitu%20Technology%20China%E3%81%8B%E3%82%89%E3%81%AE%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%8D%94%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3BBRs%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
