VR5510 test mode also at pre-programmed devices
K_Steinhammer
The documentation of the VR5510 is not clear at this point:
Is it possible to continue entering test mode or debug mode with an already programmed device in order to continue testing of parameter sets like it is possible with an un-programmed (empty) device?
  Klaus
PS: I know that I can program the device only once, but I want to know if I can continue to use an already programmed device for further optimizing the parameter set during development testing.
diazmarin09
Hello Klaus,
I hope all is great with you.
You are correct, you will be able to enter in Debug mode even with a programmed device. You may follow the procedure mentioned on datasheet, chapter 8.12.
I hope this information helps.
David
diazmarin09
Hello Klaus,
David
