Unused SD functionality on PCA9451A
AEi
I am not going to use a SD card in my iMX93 application so I am wondering how to terminate the switch and LDO5 block of the PCA9451A PMIC.
1) The SW_EN has an internal pull-down and because I am not using the I2C level translator I can also leave SWIN floating, correct? SWOUT pin can then also be left unconnected?
2) What should I do with SD_VSEL and LDO5? I can't see SD_VSEL having any internal pull resistance? And do LDO5 need to have an output capacitor even when unloaded?
My application is quite space constrained so I would like to eliminate as many parts as possible.
AEi
Ok, I figured out this by myself. The iMX93 Hardware Guide's checklist states:
"If the PCA9451AHNY PMIC is used to provide power, ensure that the output L/C components of all regulators are properly connected, even if unused. Leaving any regulator output open causes a malfunction of the whole PMIC."
I would think this would be useful information to put in the PMIC's datasheet..
AEi
%3CLINGO-SUB%20id%3D%22lingo-sub-2425129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnused%20SD%20functionality%20on%20PCA9451A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20not%20going%20to%20use%20a%20SD%20card%20in%20my%20iMX93%20application%20so%20I%20am%20wondering%20how%20to%20terminate%20the%20switch%20and%20LDO5%20block%20of%20the%20PCA9451A%20PMIC.%3C%2FP%3E%3CP%3E1)%20The%20SW_EN%20has%20an%20internal%20pull-down%20and%20because%20I%20am%20not%20using%20the%20I2C%20level%20translator%20I%20can%20also%20leave%20SWIN%20floating%2C%20correct%3F%20SWOUT%20pin%20can%20then%20also%20be%20left%20unconnected%3F%3C%2FP%3E%3CP%3E2)%20What%20should%20I%20do%20with%20SD_VSEL%20and%20LDO5%3F%20I%20can't%20see%20SD_VSEL%20having%20any%20internal%20pull%20resistance%3F%20And%20do%20LDO5%20need%20to%20have%20an%20output%20capacitor%20even%20when%20unloaded%3F%3C%2FP%3E%3CP%3EMy%20application%20is%20quite%20space%20constrained%20so%20I%20would%20like%20to%20eliminate%20as%20many%20parts%20as%20possible.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2425186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unused%20SD%20functionality%20on%20PCA9451A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20I%20figured%20out%20this%20by%20myself.%20The%20iMX93%20Hardware%20Guide's%20checklist%20states%3A%3C%2FP%3E%3CP%3E%22If%20the%20PCA9451AHNY%20PMIC%20is%20used%20to%20provide%20power%2C%20ensure%20that%20the%20output%20L%2FC%20components%20of%20all%20regulators%20are%20properly%20connected%2C%20even%20if%20unused.%26nbsp%3BLeaving%20any%20regulator%20output%20open%20causes%20a%20malfunction%20of%20the%20whole%20PMIC.%22%3C%2FP%3E%3CP%3EI%20would%20think%20this%20would%20be%20useful%20information%20to%20put%20in%20the%20PMIC's%20datasheet..%3C%2FP%3E%3C%2FLINGO-BODY%3E
