I am not going to use a SD card in my iMX93 application so I am wondering how to terminate the switch and LDO5 block of the PCA9451A PMIC.
1) The SW_EN has an internal pull-down and because I am not using the I2C level translator I can also leave SWIN floating, correct? SWOUT pin can then also be left unconnected?
2) What should I do with SD_VSEL and LDO5? I can't see SD_VSEL having any internal pull resistance? And do LDO5 need to have an output capacitor even when unloaded?
My application is quite space constrained so I would like to eliminate as many parts as possible.
