UJA1078A CAN Error Frame isuue
1,203 次查看
mr_wcz
when we do some CAN communication preformance test with the voltage rised from 3V to normal value(12V), there are CAN error frames generated when the voltage is at 5.4V.  I want to konw to how to configure the SBC(UJA1078A) to avoid this issue.
Thanks.
0 回复数
