SRC_POR_B timing
SRC_POR_B timing
3,913 次查看
yuji_fuseki
During power-up sequence, when SRC_POR_B must be asserted  to LOW in I.MX6DL?
yuji
标记 (1)
9 回复数
3,720 次查看
yuji_fuseki
Hi Igor
OK.
I understood the SRC_POR_B requirement at power-up timing.
Thanks for your strong support.
Br,
Yuji
3,720 次查看
yuji_fuseki
Hi, Igor
Thank you for your response.
>it is necessary to wait until all other power supplies become stable.
No numerical specification from after all power supplies become stable to SRC_POR_B dessertion?
Br,
yuji
3,720 次查看
Hi Yuji
right.
3,720 次查看
yuji_fuseki
Hi, Igor
I found below explanation at the datasheet.
please let me make clear below points.
 (a)Does this meas SRC_POR_B signal can be immediately deasserted after VDD_xxx_CAP supplies are stable?
 (b)If the answer is YES for question(a), is it not necessary to wait other voltage become stable?
 (c)Decided to use I.MX6 Dual Lite. so, is there dedicated specification for SRC_POR_B timing?
Br,
Yuji
3,720 次查看
Hi Yuji
 >(a)Does this meas SRC_POR_B signal can be immediately deasserted after VDD_xxx_CAP
there is no dedicated specification for SRC_POR_B timing.
3,720 次查看
yuji_fuseki
Please response to my questions.
Br,
yuji
3,720 次查看
yuji_fuseki
Hi, Igor
Thanks for your answer.
I have an another question about SRC_POR_B timing.
When  can we provide voltage to SRC_POR_B  to release reset after power supply become stable?
Yuji
3,720 次查看
Hi Yuji
what processor used in the case, one can look at
its datasheet, power-up sequence chapter.
3,720 次查看
Hi Yuji
SRC_POR_B must be asserted immediately, at first step of power-up sequence.
