SAF3607 IC power supply requirement ?
milind_mashalka
No of Decaps required per power pin ?
recommended value of decap ?
reyes
I received an answer from the Apps team, The decoupling capacitors (100nF and 22μF) as indicated in Figure attached, should be located as close as possible to the core supply/GND ball couples A7/B7, F1/F2 and R1/R2. The decoupling capacitors should have a very low ESR.
Jose
NXP Semiconductors
reyes
First it is important to let you know that Tuner devices like the SAF360x are made for a small part of the industry, therefore information, documentation and support is very limited. Requests from this kind of devices need to comes directly from your NXP Sales or Distributor FAE representative, so, you should contact your NXP (or Distributor) Sales or FAE directly for further questions about this device.
I apologize for the problems this may cause.
However, I have been trying to get you an answer for your question from the applications engineers, so far I have not received an answer from them, but I will send you an answer as soon as I get an update.
Jose
milind_mashalka
Thank you so much for your support..i will be waiting for the answer
reyes
Jose
NXP Semiconductors
milind_mashalka
thank you so much for sharing the information i was looking for the same..
