SBC FS6501 how to switch Normal_WD mode to init_FS
871 次查看
WALNUTY
I'm try to find a way to switch FS6501 to init_FS from Normal_WD.
In datasheet, I saw that it should be a external RST could work, but doesn't mention how to use it.
Could you help explain the detail to do, like a low pulse from main controller?
BR,
Walnut.
853 次查看
TomasVaverka
You need request RSTB by sending SPI commands: RSTB_REQ in SF_OUTPUT_REQUEST register. Then, a 10ms RSTB low pulse is sent by SBC, SBC state machine will convert to INIT_FS from Normal_WD.
BRs, Tomas
