NXQ1TXH5 Standby Input and LED output behavior
2,284件の閲覧回数
tim_loose
I need to know the behavior of the LED_R and LED_G outputs while the STBY input is high.
I want to use this device in a controlled application.  The documentation problem is that the datasheet state diagram refers to "wait state" and "standby" as separate states, but the LED mode table in AN11775 refers to "standby (wait) state".
タグ(1)
2,218件の閲覧回数
reyes
Please find the answer I received from the Product group in the attached document.
This should help top clarify your questions.
Jose
NXP Semiconductors
