PROGRAMMING OF PF8100EA
2,900 次查看
Ellu24
I have developed a custom board using LS1046 and I use PF8100EA as PMIC. Now, I have 2 questuions:
1) How can I configure PMIC registers and program PF8100EA in a bare board. Is there any program or files available.
2) How can I load the program for this PMIC to LS1046?
Thanks in advance
2,884 次查看
guoweisun
We have the BSP for this PMIC please  submit ticket to get it!
Home (nxp.com)
4 回复数
2,888 次查看
Ellu24
Thanks for the reply. Can you please explain how can I configure the register content of PMIC? Is there any code available to do the same and how can I load the register content into the custom board?
Thanks in advance
2,885 次查看
guoweisun
Home (nxp.com)
2,873 次查看
Ellu24
Thank you for your reply. I will submit a ticket for this.
2,894 次查看
guoweisun
1: You can change the register content after PMIC startup but for EA version can't do OTP.
2: Can't do OTP for this EA.
