PF8200D2 power up question
2,464件の閲覧回数
m_c
Senior Contributor I
In chapter 5 of PF8200D2 configuration report <https://www.nxp.com/docs/en/supporting-information/R_PF8200D2.PDF>.
It shows SW7/LDO1~4/PGOOD are OFF when power up.
Is that means LDO1~4 are keep OFF when PF8200 power up.
After RESETBMCU, MCU(S32V) will setup LDO1~4 output voltage by i2c.
2,256件の閲覧回数
guoweisun
You have correct understanding about this topic!
2,257件の閲覧回数
guoweisun
