PF8200 OTP programming
3,691 次查看
nelson_scheja
I'm planning to use the PF8200 in a project, and I want to program the OTP values so that the embedded application does not need to setup everything every time. I read that it's possible to program these via I2C, but I cannot find any additional information for that. The datasheet just states "contact NXP".
So, how is the OTP programmed?
3,266 次查看
reyes
Hi Nelson,
The PF8100 datasheet can be found in the following link: https://www.nxp.com/docs/en/data-sheet/PF8100_PF8200.pdf
The OTP programming specification or similar document is not released yet since this PMIC is a pre-production device. For additional information you need to contact your authorized distributor.
https://www.nxp.com/support/sample-buy/distributor-network:DISTRIBUTORS
Consult with your distributor, some of our authorized distributors can pre-program your PMICs with your desired OTP configuration before they send them to you. Some distributors can program the parts for a cost.
Jose
3,267 次查看
reyes
Hi Nelson,
Jose
