PF3001 Coin Cell Charger
haidoan
Hi everyone,
I'm using iMX6UL with PF3001, and need the backup battery for RTC and anti-tamper. Instead of non-rechargeable battery, I'd like to try the rechargeable lithium battery, for example Panasonic ML-1220/V1AN (ML-1220/V1AN Panasonic - BSG | Battery Products | DigiKey )
According to PF3001 specs, the charge current is only 60uA, thus too small for any rechargeable battery out there.
My question: can I use the Charge function of PF3001 for the battery above? Thanks
Tags (2)
reyes
Yes, you can use the COIN CELL charger of the PF3001 to charge the Panasonic ML coin cell battery.
haidoan
Hi Jose
Thank you. I will try.
