Maximum force for applying heatsink
1,062 次查看
jeroenvanandel
What is the maximum force for the following components:
PMIC:  PCA9450CHNY & PCA9450AAHNY:  56 HVQFN  package
1,043 次查看
TomasVaverka
We do not specify a maximum heatsink mounting force. We recommend to use thermal vias and a large ground pad under the EP to spread heat to the PCB. This is the primary intended method for thermal dissipation. If in your application a heatsink must be mounted on top, JEDEC recommends ≤20N for small QFN packages.
BRs, Tomas
1,044 次查看
TomasVaverka
BRs, Tomas
