MWCT1000 - deviceFaultStatus error code definitions?
807 次查看
droberson
We are debugging a charging issue on a custom board using the MWCT1000. In my debugging efforts, I am looking at RunTimeParams[0].wDeviceFaultStatus along with a few other run time parameters. Where are the wDeviceFaultStatus values defined? I don't see them in the WCT Runtime Debug User Guide.pdf. The values are also not defined in the WCT1000_A11_V3.3 project file from what I can see.
Derek
0 回复数
