MMPF0100NPAZES
MMPF0100NPAZES
isagani
Dear Support,
Good day,
For the part number MMPF0100NPAZES, Please advise on how can we know the time when the parts were programmed? Can we check the time/date when is the parts were programmed? Thanks
guoweisun
You can use the socket board to read out the programmed data.
EVB OTP Programming Socket for PMIC Devices | NXP Semiconductors
guoweisun
'NP' means no programmed.
isagani
OK noted on this, what if this was programmed. Can we check the time/ date this part were programmed? How can we check when this part programmed?
