MC33771 design issue
2,078 次查看
kentseng
Dear Sir
Now I'm designing a BMS, I use the MC37771 as the AFE chip, but some GPIO pin no used,
I saw the Datasheet, GPIO pin have Internal pull-down resistor.
So I should let those pins floating or pull-up/pull-down?
1,871 次查看
guoweisun
You can configure them as input then short GPIO to ground.
1,871 次查看
guoweisun
1,872 次查看
guoweisun
