MC33771 cell balancing - how does it work?
ソリューションへジャンプ
3,279件の閲覧回数
jbirchy
How does the actually cell balancing in the MC3377x devices work?
Maybe I’m missing it in the docs but I’m trying to understand how/when the balancing turns on/off.
Are there parameters in the device to affect it or is it hard fixed in silicon?
タグ(2)
3,270件の閲覧回数
guoweisun
You can get the full datasheet then read it out,for example in the MC33772 rev6.0 page51,there are more detail for introduce it!
2 返答(返信)
3,233件の閲覧回数
guoweisun
Q:That section of the datasheet just explains how to enable/disable cell balancing, it doesn't explain how it actually operates - what happens at various cell voltages or temperatures for instance, and is that adjustable or fixed in silicon?
[gw]Don't suggest to post this kind of  BMS questions on public community, because all of the related documentations are confidential MC3377X/MC33664.
I suggest you submit ticket for your case.
3,271件の閲覧回数
guoweisun
