How to start up the FS4500 SBC?
rohini_khatkale
When I power on the FS4500 ,SBC remain ON for few Seconds and again turns OFF.
I want to show you schematic if there is anything wrong in hardware please correct me.
Thanks in advance
guoweisun
Please enter into debug mode for hardware test:
The DEBUG pin allows the product to enter debug mode. To activate the debug mode, voltage applied to the DEBUG pin must be within the VDEBUG_IL and VDEBUG_IH range at start-up. If the voltage applied to DEBUG pin is out of these limits, during the SELECT pin configuration, the device settles into normal mode.
