1. On page 33:
How to understand "the fault condition is cleard"?
For example, if SW1 shutdown due to OV fault, I suppose that user clears the SW1_OV_S bit by I2C means clear the fault condition. Am I right?
2. On page 33~34:
A) How can processor reset the counter value ? I found the FAULT_CNT[3:0] is Read only.
B) Again, how to understand "the faults have been cleared ?"
1: fault condition clear means the fault condition disappear not clear the fault bit.
2:FAULT_CNT[3:0] can be read and write I test it in EVB.
3:Same answer with questions1.
