FS85 Debug mode: dumb mode possible?
2,205 次查看
AndreasStolze
as far as I understand the FS85 data sheet, in debug mode the FS85 will not turn on its regulators.
I guess if you use the KITFS85SKTEVM you can create a dummy OTP config and work with that (turning on the regulators).
However, if the FS85 is in a custom circuit, is there a way to just turn it on with its OTP configured regulator voltages? No watchdog or soever?
This would be very helpful for the board bring-up.
Andreas
2,191 次查看
guoweisun
You can see below debug flow chart, in debug mode if you do the OTP or emulation to turn on regulators, then regulators will power up according OTP/emulation configuration :
2,182 次查看
AndreasStolze
Thanks for clearing that up @guoweisun
Apparently we didn't do the right steps for debug mode. But now it works!
2,192 次查看
guoweisun
