FS6500 Wake up
FS6500 Wake up
2,002 次查看
Wen666
I want to ask about the process of sleep mode to normal mode still need to follow the same process of electric reset.
1,980 次查看
TomasVaverka
Hi Lincheng,
When a wake-up event is detected, the device starts the main state machine again by detecting the VPRE configuration (buck or buck-boost), the wake-up source is reported to the dedicated SPI register and the fail-safe state machine is also restarted.
Fail safe registers configuration will lost to default value after wake-up from Sleep mode. Main registers configuration will not lost after wake-up from Sleep mode.
BRs, Tomas
1,981 次查看
TomasVaverka
Hi Lincheng,
BRs, Tomas
1,949 次查看
Wen666
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-1963946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS6500%E5%94%A4%E9%86%92%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E9%97%AE%E4%B8%80%E4%B8%8B%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E8%BD%AC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E7%9A%84%E8%BF%87%E7%A8%8B%E8%BF%98%E6%98%AF%E9%9C%80%E8%A6%81%E6%8C%89%E7%85%A7%E7%94%B5%E6%BA%90%E5%A4%8D%E4%BD%8D%E7%9A%84%E7%9B%B8%E5%90%8C%E6%B5%81%E7%A8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS6500%20%E5%94%A4%E9%86%92%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
