FS6500 Wake up
FS6500 Wake up
Wen666
I want to ask about the process of sleep mode to normal mode still need to follow the same process of electric reset.
TomasVaverka
Hi Lincheng,
When a wake-up event is detected, the device starts the main state machine again by detecting the VPRE configuration (buck or buck-boost), the wake-up source is reported to the dedicated SPI register and the fail-safe state machine is also restarted.
Fail safe registers configuration will lost to default value after wake-up from Sleep mode. Main registers configuration will not lost after wake-up from Sleep mode.
BRs, Tomas
TomasVaverka
Hi Lincheng,
BRs, Tomas
Wen666
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-1963946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS6500%20Wake%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20want%20to%20ask%20about%20the%20process%20of%20sleep%20mode%20to%20normal%20mode%20still%20need%20to%20follow%20the%20same%20process%20of%20electric%20reset.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6500%20Wake%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1964228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS6500%20Wake%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lincheng%2C%3C%2FP%3E%0A%3CP%3EWhen%20a%20wake-up%20event%20is%20detected%2C%20the%20device%20starts%20the%20main%20state%20machine%20again%20by%20detecting%20the%20VPRE%20configuration%20(buck%20or%20buck-boost)%2C%20the%20wake-up%20source%20is%20reported%20to%20the%20dedicated%20SPI%20register%20and%20the%20fail-safe%20state%20machine%20is%20also%20restarted.%3C%2FP%3E%0A%3CP%3EFail%20safe%20registers%20configuration%20will%20lost%20to%20default%20value%20after%20wake-up%20from%20Sleep%20mode.%20Main%20registers%20configuration%20will%20not%20lost%20after%20wake-up%20from%20Sleep%20mode.%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
