FS6500 Wake up
263件の閲覧回数
Wen666
I want to ask about the process of sleep mode to normal mode still need to follow the same process of electric reset.
241件の閲覧回数
TomasVaverka
Hi Lincheng,
When a wake-up event is detected, the device starts the main state machine again by detecting the VPRE configuration (buck or buck-boost), the wake-up source is reported to the dedicated SPI register and the fail-safe state machine is also restarted.
Fail safe registers configuration will lost to default value after wake-up from Sleep mode. Main registers configuration will not lost after wake-up from Sleep mode.
BRs, Tomas
2 返答(返信)
242件の閲覧回数
TomasVaverka
Hi Lincheng,
BRs, Tomas
210件の閲覧回数
Wen666
Thank you
