FS26 Safety Outputs release
dingyazhou
Hello, I want to ask whether the fail-safe output release function Sbc_fs26_FsxbRelease of the FS26 chip needs to be called in a loop
TomasVaverka
Hello Yazhou,
It is necessary to write a 1 in order to clear the error flags bits. This is typically denoted in the FS26xx datasheet as “Clear on write to 1.”
Tomas
TomasVaverka
Hello Yazhou,
There is no need to call this function in a loop to release FSxB.
The below diagram provides high level flow chart to enter Normal mode in the application.
Tomas
dingyazhou1
Hello, I have another question, is our error flag register, such as FS_OVUV_REG_STATUS register is cleared after error clearance, or do you need to manually write "1" software?
TomasVaverka
Hello Yazhou,
Tomas
