cannot find -laio
cannot find -laio
4,056 次查看
xunxun
when I building hello-mod (fio) ,an error  occurred,below is the error message. QorIQ-SDK-V1.3.2-20130325-yocto/build_p2041rdb_release/tmp/sysroots/i686-linux/usr/libexec/ppce500mc-fsl-linux/gcc/powerpc-fsl-linux/4.6.2/ld:cannot find -laio how to solve this error,help me please
3,794 次查看
yipingwang
Hello XunXun,
SDK 1.6 has already integrated the package "fio" in meta-oe/meta-oe/recipes-benchmark.
I attached the recipe for you, please use it directly or modify your recipe based on it.
Yiping Wang
4 回复数
3,794 次查看
yipingwang
Hello XunXun,
Probably you missed some dependence packages, please kindly provide your build procedure and the error log.
Yiping Wang
3,792 次查看
xunxun
hello Yiping
thank you for your reply
"log.do_compile.txt" is the error log file.
I used the "hello-mod" as the template to compile "fio-2.1.4.tar.bz2"
I changed all files in "hello-mod\files" ,then modified the content of file "hello-mod_0.1.bb"
then I excuted the command "bitbake hello-mod"
3,795 次查看
yipingwang
Hello XunXun,
Yiping Wang
3,791 次查看
xunxun
According to the method you provided, I solved the problem
thank you
