Reflector on P4080DS is not working
4,913件の閲覧回数
sharathchandra
I am trying to start reflector on my P4080DS board. As I mentioned in the SDKv1.7 documentation, I tried to run the script SOURCE_THIS under root, but it gives the error as below:
root@p4080ds:~# source /root/SOURCE_THIS
ERR : Invocation of FM_PORT_Open for fm1/port/MAC/9 failed
ERR : Invocation of FM_PCD_Disable for fm0/pcd failed with error code 0x00010028
apps/lib/usdpaa_netcfg_layer.c:577:usdpaa_netcfg_acquire(): fmc_netcfg_get_info()
error: failed to load configuration
root@p4080ds:/usr/etc#
And if I try to run the same script again, it gives another error:
root@p4080ds:/usr/etc# source /root/SOURCE_THIS
cpu2/2: ! MAJOR FM-PCD Error [CPU02, drivers/net/ethernet/freescale/fman/Peripherals/FM/Pcd/fm_kg.c:2979 FM_PCD_KgSchemeSet]: Resource Already Exists;
cpu2/2: Scheme id (0)!cpu2/2:
cpu2/2: ! MINOR FM Error [CPU02, drivers/net/ethernet/freescale/fman/src/wrapper/lnxwrp_ioctls_fm.c:3198 LnxwrpFmPcdIOCTL]: Invalid Value;
cpu2/2: IOCTL FM PCDcpu2/2:
ERR : Invocation of FM_PCD_KgSchemeSet for fm1/port/MAC/3/dist/hash_ipsec_src_dst_spi_dist8 failed
Also, when I checked config files under /usr/etc for the board, I found the following four
usdpaa_config_p4_serdes_0x10.xml
usdpaa_config_p4_serdes_0xe.xml
usdpaa_config_p4_serdes_0x16.xml
usdpaa_config_p4_serdes_0xe_offline_host.xml
I even gave the memory for usdpaa under bootargs, like usdpaa_mem=256M, then also this error was coming.
Also could you please suggest how to resolve this error, and which config file to use with reflector and when?
Sharath Chandra
3,884件の閲覧回数
yipingwang
Hello Sharath Chandra,
Please make sure to use dtb file for USDPAA, I didn't find your log including the following information.
fsl_dpa_shared: FSL DPAA Shared Ethernet driver ()
fsl_dpa_proxy: FSL DPAA Proxy initialization driver ()
fsl_dpa_proxy-proxy ethernet.18: probed MAC device with MAC address: 00:e0:0c:00:27:04
fsl_dpa_proxy-proxy ethernet.19: probed MAC device with MAC address: 00:e0:0c:00:27:07
fsl_dpa_proxy-proxy ethernet.20: probed MAC device with MAC address: 00:e0:0c:00:27:08
fsl_dpa_proxy-proxy ethernet.21: probed MAC device with MAC address: 00:e0:0c:00:27:09
fsl_oh: FSL FMan Offline Parsing port driver ()
Please refer to the following normal boot log.
done
Bytes transferred = 42075 (a45b hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 01000000 ...
  Image Name:  Linux-3.12.19-rt30-QorIQ-SDK-V1.
  Image Type:  PowerPC Linux Kernel Image (gzip compressed)
  Data Size:    4251655 Bytes = 4.1 MiB
  Load Address: 00000000
  Entry Point:  00000000
  Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
  Image Name:  fsl-image-core-p4080ds-201412140
  Image Type:  PowerPC Linux RAMDisk Image (gzip compressed)
  Data Size:    29815307 Bytes = 28.4 MiB
## Flattened Device Tree blob at 00c00000
  Booting using the fdt blob at 0xc00000
  Uncompressing Kernel Image ... OK
  Loading Ramdisk to 2e390000, end 2ffff20b ... OK
  Loading Device Tree to 03fe2000, end 03fff45a ... OK
Using CoreNet Generic machine description
Memory CAM mapping: 256/256/256 Mb, residual: 3328Mb
Linux version 3.12.19-rt30-QorIQ-SDK-V1.7+g6619b8b (jenkins@neptune) (gcc version 4.8.1 (GCC) ) #1 SMP Sat Dec 13 11:33:47 CST 2014
Found initrd at 0xee390000:0xeffff20b
No /soc@ffe000000/qman@318000 property 'fsl,qman-fqd', using memblock_alloc(0000000000400000)
No /soc@ffe000000/qman@318000 property 'fsl,qman-pfdr', using memblock_alloc(0000000002000000)
Qman ver:0a01,01,02,00
No /soc@ffe000000/bman@31a000 property 'fsl,bman-fbpr', using memblock_alloc(0000000001000000)
Bman ver:0a02,01,00
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-pdsr', using memblock_alloc(0x0000000001000000)
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-sre', using memblock_alloc(0x0000000000a00000)
USDPAA region at 10000000:10000000(10000:10000), 1 TLB1 entries)
CPU maps initialized for 1 thread per core
bootconsole [udbg0] enabled
setup_arch: bootmem
CoreNet Generic board from Freescale Semiconductor
arch: exit
Zone ranges:
  DMA      [mem 0x00000000-0x2fffffff]
  Normal  empty
  HighMem  [mem 0x30000000-0xffffffff]
Movable zone start for each node
Early memory node ranges
  node  0: [mem 0x00000000-0xffffffff]
MMU: Allocated 1088 bytes of context maps for 255 contexts
PERCPU: Embedded 8 pages/cpu @c295b000 s9792 r8192 d14784 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1047040
Kernel command line: root=/dev/ram rw console=ttyS0,115200 usdpaa_mem=256M bportals=s0-1 qportals=s0-1
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Sorting __ex_table...
Memory: 3713320K/4194304K available (6656K kernel code, 332K rwdata, 1768K rodata, 272K init, 452K bss, 480984K reserved, 3407860K highmem)
Kernel virtual memory layout:
  * 0xfff5f000..0xfffff000  : fixmap
  * 0xffc00000..0xffe00000  : highmem PTEs
  * 0xffbfb000..0xffc00000  : early ioremap
  * 0xf1000000..0xffbfb000  : vmalloc & ioremap
Hierarchical RCU implementation.
        RCU debugfs-based tracing is enabled.
NR_IRQS:512 nr_irqs:512 16
mpic: Setting up MPIC " OpenPIC  " version 1.2 at ffe040000, max 8 CPUs
mpic: ISU size: 512, shift: 9, mask: 1ff
mpic: Initializing for 512 sources
clocksource: timebase mult[14000d1b] shift[24] registered
Console: colour dummy device 80x25
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
mpic: requesting IPIs...
e500 family performance monitor hardware support registered
Brought up 8 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
Found FSL PCI host bridge at 0x0000000ffe200000. Firmware bus number: 0->1
PCI host bridge /pcie@ffe200000  ranges:
MEM 0x0000000c00000000..0x0000000c1fffffff -> 0x00000000e0000000
  IO 0x0000000ff8000000..0x0000000ff800ffff -> 0x0000000000000000
/pcie@ffe200000: PCICSRBAR @ 0xdf000000
/pcie@ffe200000: Setup 64-bit PCI DMA window
/pcie@ffe200000: DMA window size is 0xdf000000
EDAC PCI0: Giving out device to module 'MPC85xx_edac' controller 'mpc85xx_pci_err': DEV 'ffe200000.pcie' (INTERRUPT)
MPC85xx_edac acquired irq 482 for PCI Err
MPC85xx_edac PCI err registered
Found FSL PCI host bridge at 0x0000000ffe202000. Firmware bus number: 0->0
PCI host bridge /pcie@ffe202000  ranges:
MEM 0x0000000c40000000..0x0000000c5fffffff -> 0x00000000e0000000
  IO 0x0000000ff8020000..0x0000000ff802ffff -> 0x0000000000000000
/pcie@ffe202000: PCICSRBAR @ 0xdf000000
/pcie@ffe202000: Setup 64-bit PCI DMA window
/pcie@ffe202000: DMA window size is 0xdf000000
EDAC PCI1: Giving out device to module 'MPC85xx_edac' controller 'mpc85xx_pci_err': DEV 'ffe202000.pcie' (INTERRUPT)
MPC85xx_edac acquired irq 480 for PCI Err
software IO TLB [mem 0x03ff7000-0x07ff7000] (64MB) mapped at [c3ff7000-c7ff6fff]
PCI: Probing PCI hardware
fsl-pci ffe200000.pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0xf1040000-0xf104ffff] (bus address [0x0000-0xffff])
pci_bus 0000:00: root bus resource [mem 0xc00000000-0xc1fffffff] (bus address [0xe0000000-0xffffffff])
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:00.0: ignoring class 0x0b2000 (doesn't match header type 01)
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
fsl-pci ffe202000.pcie: PCI host bridge to bus 0001:02
pci_bus 0001:02: root bus resource [io  0xf1060000-0xf106ffff] (bus address [0x0000-0xffff])
pci_bus 0001:02: root bus resource [mem 0xc40000000-0xc5fffffff] (bus address [0xe0000000-0xffffffff])
pci_bus 0001:02: root bus resource [bus 02-ff]
pci 0001:02:00.0: ignoring class 0x0b2000 (doesn't match header type 01)
pci 0001:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0001:02:00.0: PCI bridge to [bus 03-ff]
pci 0000:00:00.0: BAR 9: can't assign mem pref (size 0x100000)
pci 0000:01:00.0: BAR 6: assigned [mem 0xc00040000-0xc0005ffff pref]
pci 0000:00:00.0: PCI bridge to [bus 01]
pci 0000:00:00.0:  bridge window [io  0xf1040000-0xf104ffff]
pci 0000:00:00.0:  bridge window [mem 0xc00000000-0xc1fffffff]
pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
pci 0001:02:00.0: PCI bridge to [bus 03]
pci 0001:02:00.0:  bridge window [io  0xf1060000-0xf106ffff]
pci 0001:02:00.0:  bridge window [mem 0xc40000000-0xc5fffffff]
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Bman err interrupt handler present
Bman portal (shared) initialised, cpu 0
Bman portal (shared) initialised, cpu 1
Bman portal (slave) initialised, cpu 2
Bman portal (slave) initialised, cpu 3
Bman portal (slave) initialised, cpu 4
Bman portal (slave) initialised, cpu 5
Bman portal (slave) initialised, cpu 6
Bman portal (slave) initialised, cpu 7
Bman portals initialised
Qman err interrupt handler present
Qman portal (shared) initialised, cpu 0
Qman portal (shared) initialised, cpu 1
Qman portal (slave) initialised, cpu 2
Qman portal (slave) initialised, cpu 3
Qman portal (slave) initialised, cpu 4
Qman portal (slave) initialised, cpu 5
Qman portal (slave) initialised, cpu 6
Qman portal (slave) initialised, cpu 7
Qman portals initialised
Bman: BPID allocator includes range 32:32
Qman: FQID allocator includes range 256:256
Qman: FQID allocator includes range 32768:32768
Qman: CGRID allocator includes range 0:256
Qman: pool channel allocator includes range 33:15
Switched to clocksource timebase
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 29116K (ee390000 - effff000)
audit: initializing netlink socket (disabled)
type=2000 audit(0.412:1): initialized
bounce pool size: 64 pages
HugeTLB registered 1 MB page size, pre-allocated 0 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
HugeTLB registered 64 MB page size, pre-allocated 0 pages
HugeTLB registered 256 MB page size, pre-allocated 0 pages
HugeTLB registered 1 GB page size, pre-allocated 0 pages
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/O].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 653
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xffe11c500 (irq = 36, base_baud = 24999750) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0xffe11c600 (irq = 36, base_baud = 24999750) is a 16550A
serial8250.0: ttyS2 at MMIO 0xffe11d500 (irq = 37, base_baud = 24999750) is a 16550A
serial8250.0: ttyS3 at MMIO 0xffe11d600 (irq = 37, base_baud = 24999750) is a 16550A
ePAPR hypervisor byte channel driver
Generic non-volatile memory driver v1.1
brd: module loaded
loop: module loaded
st: Version 20101219, fixed bufsize 32768, s/g segs 256
fe8000000.flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002801
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
fsl_espi ffe110000.spi: master is unqueued, this is deprecated
m25p80 spi32766.0: s25sl12801 (16384 Kbytes)
4 ofpart partitions found on MTD device spi32766.0
Creating 4 MTD partitions on "spi32766.0":
0x000000000000-0x000000100000 : "u-boot"
0x000000100000-0x000000600000 : "kernel"
0x000000600000-0x000000700000 : "dtb"
0x000000700000-0x000001000000 : "file system"
fsl_espi ffe110000.spi: at 0xf117a000 (irq = 53)
libphy: Fixed MDIO Bus: probed
platform mdio-mux-emi1.14: Driver mdio-mux-gpio requests probe deferral
platform mdio-mux-emi2.15: Driver mdio-mux-gpio requests probe deferral
libphy: Freescale PowerQUICC MII Bus: probed
libphy: Freescale XGMAC MDIO Bus: probed
Freescale FM module (Dec 13 2014:11:33:32), FMD API version 21.1.0
Freescale FM Ports module (Dec 13 2014:11:33:32)
dpaa_debugfs: FSL DPAA Ethernet debugfs entries ()
dpaa_generic_debugfs: FSL DPAA Ethernet debugfs entries ()
fsl_mac: fsl_mac: FSL FMan MAC API based driver ()
fsl_mac ffe4e0000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe4e0000.ethernet: FMan MAC address: 00:e0:0c:00:27:00
fsl_mac ffe4e2000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe4e2000.ethernet: FMan MAC address: 00:e0:0c:00:27:01
cpu3/3: Applying 10G TX ECC workaround (10GMAC-A004) ...
cpu3/3: done.
fsl_mac ffe4f0000.ethernet: FMan XGEC version: 0x00010330
fsl_mac ffe4f0000.ethernet: FMan MAC address: 00:e0:0c:00:27:04
fsl_mac ffe5e4000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe5e4000.ethernet: FMan MAC address: 00:e0:0c:00:27:07
fsl_mac ffe5e6000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe5e6000.ethernet: FMan MAC address: 00:e0:0c:00:27:08
cpu3/3: done.
fsl_mac ffe5f0000.ethernet: FMan XGEC version: 0x00010330
fsl_mac ffe5f0000.ethernet: FMan MAC address: 00:e0:0c:00:27:09
fsl_dpa: FSL DPAA Ethernet driver ()
fsl_dpa: fsl_dpa: Probed interface eth0
fsl_oh dpa-fman0-oh.22: Found OH node handle compatible with fsl,dpa-oh.
fsl_oh dpa-fman0-oh.22: Allocating 0 ingress frame queues duples
fsl_oh dpa-fman0-oh.22: OH port /soc@ffe000000/fman@400000/port@82000 has no buffer pool. Fragmentation will not be enabled
fsl_oh dpa-fman0-oh.22: OH port /soc@ffe000000/fman@400000/port@82000 enabled.
fsl_oh dpa-fman0-oh.22: Default egress frame queue: 105
fsl_oh dpa-fman0-oh.22: Default error frame queue: 104
fsl_oh dpa-fman0-oh.22: Initialized queues:
e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
e1000e 0000:01:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
e1000e 0000:01:00.0 eth1: (PCI Express:2.5GT/s:Width x1) 00:15:17:81:1a:a4
e1000e 0000:01:00.0 eth1: Intel(R) PRO/1000 Network Connection
e1000e 0000:01:00.0 eth1: MAC: 1, PHY: 4, PBA No: D50858-004
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 44, io mem 0xffe210000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
mpc-i2c ffe118100.i2c: timeout 1000000 us
rtc-ds3232 0-0068: rtc core: registered ds3232 as rtc0
mpc-i2c ffe118000.i2c: timeout 1000000 us
mpc-i2c ffe119000.i2c: timeout 1000000 us
mpc-i2c ffe119100.i2c: timeout 1000000 us
Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
EDAC MC0: Giving out device to 'MPC85xx_edac' 'mpc85xx_mc_err': DEV mpc85xx_mc_err
MPC85xx_edac acquired irq 490 for MC
MPC85xx_edac MC err registered
EDAC MC1: Giving out device to 'MPC85xx_edac' 'mpc85xx_mc_err': DEV mpc85xx_mc_err
MPC85xx_edac acquired irq 489 for MC
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on ffe114000.sdhc [ffe114000.sdhc] using DMA
platform caam_qi.0: Linux CAAM Queue I/F driver initialised
caam ffe300000.crypto: device ID = 0x0a10030000000000 (Era 4)
caam ffe300000.crypto: job rings = 4, qi = 1
caam algorithms registered in /proc/crypto
caam_jr ffe301000.jr: registering rng-caam
mmc0: new SDHC card at address ff36
caam ffe300000.crypto: fsl,sec-v4.0 algorithms registered in /proc/crypto
platform caam_qi.0: fsl,sec-v4.0 algorithms registered in /proc/crypto
mmcblk0: mmc0:ff36 SD04G 3.69 GiB
Freescale USDPAA process driver
mmcblk0: p1
Freescale USDPAA process IRQ driver
fsl-pme ffe316000.pme: ver: 0x00100201
Freescale pme2 db driver
Freescale pme2 scan driver
fsl-pme2-scan: device pme_scan registered
Freescale hypervisor management driver
fsl-hv: no hypervisor found
ipip: IPv4 over IPv4 tunneling driver
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
libphy: mdio_mux: probed
mdio-mux-gpio mdio-mux-emi1.14: Version 1.0
mdio-mux-gpio mdio-mux-emi2.15: Version 1.0
fsl_dpa_macless: FSL DPAA MACless Ethernet driver ()
fsl_dpa_generic: FSL DPAA Generic Ethernet driver ()
rtc-ds3232 0-0068: setting system clock to 2015-04-03 08:52:33 UTC (1428051153)
RAMDISK: gzip image found at block 0
usb 1-1: new high-speed USB device number 2 using fsl-ehci
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi0 : usb-storage 1-1:1.0
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 272K (c083e000 - c0882000)
INIT: version 2.88 booting
scsi 0:0:0:0: Direct-Access    Kingston DT 101 G2        1.00 PQ: 0 ANSI: 2
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 3913664 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
Starting udev
udevd[1049]: starting version 182
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
Populating dev cache
net.ipv4.conf.default.rp_filter = 0
net.ipv4.conf.all.rp_filter = 0
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
Running postinst /etc/rpm-postinsts/101-debianutils...
Running postinst /etc/rpm-postinsts/102-inetutils-inetd...
Running postinst /etc/rpm-postinsts/103-util-linux-readprofile...
Running postinst /etc/rpm-postinsts/104-inetutils-telnetd...
Running postinst /etc/rpm-postinsts/105-inetutils-tftpd...
Running postinst /etc/rpm-postinsts/106-inetutils-ftpd...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... done.
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCFHycORuOQXRawY94J5e84Ji7gEhEKq3h47C12UXCQQflIvn97Sb7UgoFK6+hcD7qfJd6cGagEcjDwZe2AUVXP8ivdYRJdBhR2hE1ldekr8gcKi9waiWB7FYu0f3vHa5hdcqaTvfaUFGemW4Xz2dTdfUx7WprHR27l0iKl2Q6tLNEoPiHsl2CLKiOsTZfSHXYplX82+JVI7QY7Q3jwLXMtnaRCjWtex1/BoaMgmCxzNo9gmO8UNUSkbbhQKO6ciLFboSdacVaxlmDZB8sTxV6fMUkSzKeXSVmi615fyqXnJpoOH5evC23CHOcV7+a40mXOv6ow/45OZW/wybDNL6GD root@p4080ds
Fingerprint: md5 27:11:27:e6:84:56:66:2a:8a:d1:e6:0b:88:b4:22:c7
dropbear.
Starting network benchmark server: netserver.
Starting system log daemon...0
Starting kernel log daemon...0
Starting internet superserver: xinetd.
Stopping Bootlog daemon: bootlogd.
Poky (Yocto Project Reference Distro) 1.6.1 p4080ds /dev/ttyS0
Yiping
7 返答(返信)
3,884件の閲覧回数
yipingwang
The following is the content of script /root/SOURCE_THIS,
cd /usr/etc
fmc -c usdpaa_config_p4_serdes_0xe.xml -p usdpaa_policy_hash_ipv4.xml -a
reflector
Which RCW are you using on your target board? Serdes 0x16, 0x10 or 0xe?
Please choose an appropriate fmc configuration file according to RCW on your target, then run them following commands.
cd /usr/etc
fmc -c <configuraton file> -p usdpaa_policy_hash_ipv4.xml -a
reflector
If the further assistance is needed, please share your u-boot boot log.
Yiping
3,884件の閲覧回数
sharathchandra
Hi Yiping,
I dont know which RCW is loaded on to the board, as I was using what came with the board itself. So I tried with all the config files i.e, 0x10, 0xe, 0x16, 0xe_offline. For all them it gives same error as above "Invocation of port failed, failed to load configuration".
As I was not able to figure out the RCW I am using, after your reply,I loaded rcw_13g_1500mhz_rev3.bin which is Serdes 0x10 and edited the script file SOURCE_THIS to use config for 0x10. Then also it was giving same error.
I am using fm1-gb1 ethernet port and
My U-Boot log as displaced:
U-Boot 2011.12-00064-gbfb0c9a (Jun 15 2012 - 16:09:09)
CPU0:  P4080E, Version: 3.0, (0x82080030)
Core:  E500MC, Version: 3.1, (0x80230031)
Clock Configuration:
       CPU0:1499.985 MHz, CPU1:1499.985 MHz, CPU2:1499.985 MHz, CPU3:1499.985 MHz,
       CPU4:1499.985 MHz, CPU5:1499.985 MHz, CPU6:1499.985 MHz, CPU7:1499.985 MHz,
       CCB:799.992 MHz,
       DDR:649.994 MHz (1299.987 MT/s data rate) (Asynchronous), LBC:99.999 MHz
       FMAN1: 599.994 MHz
       FMAN2: 599.994 MHz
       PME:   399.996 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Board: P4080DS, Sys ID: 0x17, Sys Ver: 0x01, FPGA Ver: 0x0c, vBank: 0
36-bit Addressing
Reset Configuration Word (RCW):
       00000000: 105a0000 00000000 1e1e181e 0000cccc
       00000010: 40464000 3c3c2000 fe800000 61000000
       00000020: 00000000 00000000 00000000 008b6000
       00000030: 00000000 00000000 00000000 00000000
SERDES Reference Clocks: Bank1=100MHz Bank2=125MHz Bank3=125MHz
I2C:   ready
SPI:   ready
DRAM:  Initializing....using SPD
Detected UDIMM i-DIMM
CS2 is disabled.
CS3 is disabled.
CS2 is disabled.
CS3 is disabled.
2 GiB left unmapped
4 GiB (DDR3, 64-bit, CL=9, ECC off)
       DDR Controller Interleaving Mode: cache line
       DDR Chip-Select Interleaving Mode: CS0+CS1
Testing 0x00000000 - 0x7fffffff
Testing 0x80000000 - 0xffffffff
Remap DDR 2 GiB left unmapped
POST memory PASSED
Flash: 128 MiB
L2:    128 KB enabled
Corenet Platform Cache: 2048 KB enabled
SERDES: bank 2 disabled
SERDES: bank 3 disabled
SRIO1: disabled
SRIO2: disabled
MMC:  FSL_SDHC: 0
EEPROM: NXID v1
PCIe1: Root Complex, no link, regs @ 0xfe200000
PCIe1: Bus 00 - 00
PCIe2: disabled
PCIe3: Root Complex, x1, regs @ 0xfe202000
  02:00.0     - 1095:3132 - Mass storage controller
PCIe3: Bus 01 - 02
In:    serial
Out:   serial
Err:   serial
Net:   Fman1: Uploading microcode version 106.2.14
Fman2: Uploading microcode version 106.2.14
FM1@DTSEC2, FM2@DTSEC1, FM2@DTSEC2, FM2@DTSEC3, FM2@DTSEC4
Hit any key to stop autoboot:  0
Device: FSL_SDHC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
Loading file "/boot/uImage--3.12-r0-p4080ds-20150319153249.bin" from mmc device 0:5 (xxa5)
4277577 bytes read
Loading file "/boot/uImage--3.12-r0-p4080ds-usdpaa-20150319153249.dtb" from mmc device 0:5 (xxa5)
40428 bytes read
   Data Size:    4277513 Bytes = 4.1 MiB
   Booting using the fdt blob at 0x00c00000
   Loading Device Tree to 03fe3000, end 03fffdeb ... OK
Linux version 3.12.19-rt30-QorIQ-SDK-V1.7+g6619b8b (fslp4080ds@ubuntu) (gcc version 4.8.1 (GCC) ) #1 SMP Thu Mar 19 08:19:29 PDT 2015
Bman ver:0a02,01,00
setup_arch: bootmem
arch: exit
Zone ranges:
  Normal   empty
PERCPU: Embedded 8 pages/cpu @c2969000 s9920 r8192 d14656 u32768
Kernel command line: root=/dev/mmcblk0p5 rw rootdelay=5 console=ttyS0,115200 usdpaa_mem=256M
Memory: 3742400K/4194304K available (6700K kernel code, 332K rwdata, 1780K rodata, 272K init, 452K bss, 451904K reserved, 3407868K highmem)
Brought up 8 CPUs
Found FSL PCI host bridge at 0x0000000ffe200000. Firmware bus number: 0->0
Found FSL PCI host bridge at 0x0000000ffe202000. Firmware bus number: 0->1
software IO TLB [mem 0x03ff6000-0x07ff6000] (64MB) mapped at [c3ff6000-c7ff5fff]
pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0001:02:00.0: Primary bus is hard wired to 0
pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
pci 0001:02:00.0: BAR 9: can't assign mem pref (size 0x100000)
pci 0001:03:00.0: BAR 6: assigned [mem 0xc40080000-0xc400fffff pref]
pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
vgaarb: loaded
EDAC MC: Ver: 3.0.0
Bman portal initialised, cpu 0
Bman portal initialised, cpu 1
Bman portal initialised, cpu 2
Bman portal initialised, cpu 3
Bman portal initialised, cpu 4
Bman portal initialised, cpu 5
Bman portal initialised, cpu 6
Bman portal initialised, cpu 7
Can't find Qman clock frequency
Qman portal initialised, cpu 0
Qman portal initialised, cpu 1
Qman portal initialised, cpu 2
Qman portal initialised, cpu 3
Qman portal initialised, cpu 4
Qman portal initialised, cpu 5
Qman portal initialised, cpu 6
Qman portal initialised, cpu 7
type=2000 audit(0.194:1): initialized
brd: module loaded
loop: module loaded
scsi0 : sata_sil24
scsi1 : sata_sil24
ata1: SATA max UDMA/100 host m128@0xc40000000 port 0xc40004000 irq 42
ata2: SATA max UDMA/100 host m128@0xc40000000 port 0xc40006000 irq 42
fsl_espi ffe110000.spi: at 0xf117c000 (irq = 53)
mdio_bus mdio@ffe4e1120: cannot get PHY at address 8
Freescale FM module (Mar 19 2015:08:16:16), FMD API version 21.1.0
Freescale FM Ports module (Mar 19 2015:08:16:22)
fsl_mac ffe4e0000.ethernet: FMan MAC address: 00:04:9f:03:56:dd
fsl_mac ffe4e2000.ethernet: FMan MAC address: 00:04:9f:03:56:de
fsl_mac ffe5e0000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe5e0000.ethernet: FMan MAC address: 00:04:9f:03:56:e2
fsl_mac ffe5e2000.ethernet: FMan dTSEC version: 0x08240101
fsl_mac ffe5e2000.ethernet: FMan MAC address: 00:04:9f:03:56:e3
fsl_mac ffe5e4000.ethernet: FMan MAC address: 00:04:9f:03:56:e4
fsl_mac ffe5e6000.ethernet: FMan MAC address: 00:04:9f:03:56:e5
fsl_dpa: fsl_dpa: Probed interface eth1
fsl_dpa: fsl_dpa: Probed interface eth2
fsl_dpa: fsl_dpa: Probed interface eth3
fsl_dpa: fsl_dpa: Probed interface eth4
/soc@ffe000000/usb@210000: Invalid 'dr_mode' property, fallback to host mode
mpc85xx_mc_err_probe: No ECC DIMMs discovered
caam ffe300000.crypto: device ID = 0x0a10030000000000 (Era 1)
authenc-hmac-md5-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha1-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha224-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha256-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU04G 3.69 GiB
mmcblk0: p1 < p5 >
authenc-hmac-sha384-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha512-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-md5-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha1-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha224-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha256-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha384-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha512-cbc-des3_ede-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-md5-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha1-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha224-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha256-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha384-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
authenc-hmac-sha512-cbc-des-caam needs Era 2 or higher but SEC is Era 1, skipping it
rfc4106-gcm-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
rfc4543-gcm-aes-caam needs Era 3 or higher but SEC is Era 1, skipping it
tls10-hmac-sha1-cbc-aes-caam needs Era 2 or higher but SEC is Era 1, skipping it
cbc-3des-caam needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-md5-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha1-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha224-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha256-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha384-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha512-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-md5-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha1-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha224-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha256-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha384-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha512-cbc-des3_ede-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-md5-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha1-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha224-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha256-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha384-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: authenc-hmac-sha512-cbc-des-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
platform caam_qi.0: tls10-hmac-sha1-cbc-aes-caam-qi needs Era 2 or higher but SEC is Era 1, skipping it
rtc-ds3232 0-0068: setting system clock to 2015-03-30 10:33:31 UTC (1427711611)
Waiting 5 sec before mounting root device...
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 0)
ata1.00: ATA-8: WDC WD5000AAKX-22ERMA0, 17.01H17, max UDMA/133
ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/100
scsi 0:0:0:0: Direct-Access     ATA      WDC WD5000AAKX-2 17.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: unknown partition table
sd 0:0:0:0: [sda] Attached SCSI disk
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 0)
ata2.00: ATAPI: ATAPI   iHAS124   E, 4L06, max UDMA/100
ata2.00: configured for UDMA/100
scsi 1:0:0:0: CD-ROM            ATAPI    iHAS124   E      4L06 PQ: 0 ANSI: 5
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
cdrom: Uniform CD-ROM driver Revision: 3.20
sr 1:0:0:0: Attached scsi generic sg1 type 5
EXT2-fs (mmcblk0p5): warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem) on device 179:5.
devtmpfs: mounted
Freeing unused kernel memory: 272K (c084c000 - c0890000)
Starting udev
udevd[1081]: starting version 182
bootlogd.
Starting atd: OK
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon...done.
creating NFS state directory: done
starting statd: done
Starting domain name service: named.
starting DNS forwarder and DHCP server: dnsmasq...
dnsmasq: failed to create listening socket for port 53: Address already in use
Installing knfsd (copyright (C) 1996 [email protected]).
starting 8 nfsd kernel threads: done
starting mountd: done
Starting Samba: smbd nmbd.
Starting Lighttpd Web Server: lighttpd.
2015-03-30 10:33:38: (/local/workspace/ci/iso-make/master/p4080ds/build_p4080ds_release/tmp/work/ppce500mc-fsl-linux/lighttpd/1.4.33-r1/lighttpd-1.4.33/src/log.c.166) server started
* Starting virtualization library daemon: libvirtd
no /usr/bin/dnsmasq found; none killed
2015-03-30 10:33:49.370+0000: 1864: info : libvirt version: 1.2.2
2015-03-30 10:33:49.370+0000: 1864: warning : virGetHostname:625 : getaddrinfo failed for 'p4080ds': Name or service not known
Starting crond: OK
Starting nginx: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
Starting tcf-agent: OK
Starting web based system monitor... done.
p4080ds login: root
root@p4080ds:~#
Sharath Chandra
3,884件の閲覧回数
yipingwang
First of all, please update u-boot and FMAN ucode with images from SDK 1.7.
Please add bootargs "usdpaa_mem=256M bportals=s0-1 qportals=s0-1", this is not related with this error, but it is needed to run USDPAA application.
I suggest you to use serdes 0xe RCW to run USDPAA application, the configuration files for 0xe have already been tested. I also verified 0x10 xml configuration on my target, it seems that it doesn't match 13G RCW configuration, if you want to  use 13G RCW, you need to modify usdpaa_config_p4_serdes_0x10.xml according to your current configuration.
I attached the reflector log for serdes 0xe.
Yiping
3,884件の閲覧回数
sharathchandra
Hi Yiping,
As you suggested, we updated our system with all the images from SDK 1.7, but still we are facing the same issue.
Our P4080DS board was delivered with Freescale sch-24801 REV A2 extension board connected to Slot #3.
We don't have any physical 10g interfaces but it was being displaced on both our u-boot and linux. Is it based only on RCW configuration?
FYI, we are using  rcw_2sgmii_1500mhz_rev3.bin from SDK 1.7. Do we need 10g physical interface to run the test?
Please verify the log shown here:
U-Boot 2014.07QorIQ-SDK-V1.7+g659b6a2 (Feb 27 2015 - 08:30:18)
Core:  e500mc, Version: 3.1, (0x80230031)
       CCB:799.992 MHz,
       FMAN1: 599.994 MHz
       FMAN2: 599.994 MHz
       QMAN:  399.996 MHz
       PME:   599.994 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
       00000010: 3842440c 3c3c2000 de800000 e1000000
I2C:   ready
SPI:   ready
Remap DDR
4 GiB (DDR3, 64-bit, CL=9, ECC on)
POST memory PASSED
Flash: 128 MiB
L2:    128 KiB enabled
Corenet Platform Cache: 2 MiB enabled
SRIO1: disabled
SRIO2: disabled
MMC:   FSL_SDHC: 0
EEPROM: CRC mismatch (ba9a52e2 != ffffffff)
PCIe1: Bus 00 - 00
PCIe2: disabled
PCIe3: Root Complex, x1 gen1, regs @ 0xfe202000
PCIe3: Bus 01 - 02
In:    serial
Out:   serial
Err:   serial
Phy not found
PHY reset timed out
Phy not found
PHY reset timed out
FM1@DTSEC2 [PRIME], FM1@TGEC1, FM2@DTSEC3, FM2@DTSEC4, FM2@TGEC1
=> pri
baudrate=115200
bdev=sda3
bootargs=root=/dev/mmcblk0p5 rw rootdelay=5 console=ttyS0,115200 usdpaa_mem=256M bportals=s0-1 qportals=s0-1
bootcmd=mmcinfo;ext2load mmc 0:5 $loadaddr /boot/$bootfile;ext2load mmc 0:5 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr
bootdelay=10
bootfile=uImage--3.12-r0-p4080ds-20150319153249.bin
consoledev=ttyS0
eth1addr=00:04:9F:03:56:DE
eth2addr=00:04:9F:03:56:DF
eth3addr=00:04:9F:03:56:E0
eth4addr=00:04:9F:03:56:E1
eth5addr=00:04:9F:03:56:E2
eth6addr=00:04:9F:03:56:E3
eth7addr=00:04:9F:03:56:E4
eth8addr=00:04:9F:03:56:E5
eth9addr=00:04:9F:03:56:E6
ethact=FM1@DTSEC2
ethaddr=00:04:9F:03:56:DD
ethprime=FM1@DTSEC2
fdtaddr=c00000
fdtfile=uImage--3.12-r0-p4080ds-usdpaa-20150319153249.dtb
fman_ucode=eff00000
hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1;usb1:dr_mode=host,phy_type=ulpi;usb2:dr_mode=peripheral,phy_type=ulpi
ipaddr=10.10.10.148
loadaddr=1000000
netdev=eth0
netmask=255.255.255.0
nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr
othbootargs=usdpaa_mem=256M bportals=s0-1 qportals=s0-1
ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr
ramdiskaddr=2000000
ramdiskfile=p4080ds/ramdisk.uboot
rootpath=/opt/nfsroot
serverip=10.10.10.155
stderr=serial
stdin=serial
stdout=serial
tftpflash=tftpboot $loadaddr $uboot && protect off $ubootaddr +$filesize && erase $ubootaddr +$filesize && cp.b $loadaddr $ubootaddr $filesize && protect on $ubootaddr +$filesize && cmp.b $loadaddr $ubootaddr $filesize
uboot=u-boot.bin
ubootaddr=0xeff40000
Environment size: 1926/8188 bytes
=> boot
Device: FSL_SDHC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
4277577 bytes read in 358 ms (11.4 MiB/s)
40428 bytes read in 132 ms (298.8 KiB/s)
Bman ver:0a02,01,00
setup_arch: bootmem
arch: exit
Zone ranges:
  Normal   empty
Kernel command line: root=/dev/mmcblk0p5 rw rootdelay=5 console=ttyS0,115200 usdpaa_mem=256M bportals=s0-1 qportals=s0-1
Memory: 3742392K/4194304K available (6700K kernel code, 332K rwdata, 1780K rodata, 272K init, 452K bss, 451912K reserved, 3407860K highmem)
Brought up 8 CPUs
vgaarb: loaded
EDAC MC: Ver: 3.0.0
type=2000 audit(0.226:1): initialized
brd: module loaded
loop: module loaded
scsi0 : sata_sil24
scsi1 : sata_sil24
cpu7/7: Applying 10G TX ECC workaround (10GMAC-A004) ...
cpu7/7: done.
fsl_mac ffe4f0000.ethernet: FMan MAC address: 00:04:9f:03:56:e1
cpu7/7: done.
fsl_mac ffe5f0000.ethernet: FMan MAC address: 00:04:9f:03:56:e6
mmcblk0: p1 < p5 >
mdio_bus ffe4f1000: MDIO read error
mdio_bus 1.1: cannot get PHY at address 0
mdio_bus 1.3: cannot get PHY at address 4
rtc-ds3232 0-0068: setting system clock to 2015-03-31 14:00:35 UTC (1427810435)
devtmpfs: mounted
Starting udev
udevd[1132]: starting version 182
bootlogd.
Starting atd: OK
2015-03-31 14:00:42: (/local/workspace/ci/iso-make/master/p4080ds/build_p4080ds_release/tmp/work/ppce500mc-fsl-linux/lighttpd/1.4.33-r1/lighttpd-1.4.33/src/log.c.166) server started
2015-03-31 14:00:53.368+0000: 1945: info : libvirt version: 1.2.2
2015-03-31 14:00:53.368+0000: 1945: warning : virGetHostname:625 : getaddrinfo failed for 'p4080ds': Name or service not known
Starting crond: OK
p4080ds login: root
root@p4080ds:~#
root@p4080ds:~#
root@p4080ds:~#
root@p4080ds:~# cat /root/SOURCE_THIS
cd /usr/etc
reflector
root@p4080ds:~#
root@p4080ds:~#
root@p4080ds:~#
3,885件の閲覧回数
yipingwang
done
Bman ver:0a02,01,00
setup_arch: bootmem
arch: exit
Zone ranges:
  Normal  empty
Brought up 8 CPUs
vgaarb: loaded
EDAC MC: Ver: 3.0.0
brd: module loaded
loop: module loaded
cpu3/3: done.
cpu3/3: done.
mmcblk0: p1
devtmpfs: mounted
sda: sda1
Starting udev
bootlogd.
dropbear.
Yiping
3,884件の閲覧回数
sharathchandra
Hi Yiping,
The reflector show that it uses two 1G ports and two 10G ports. But I dont think my system has any 10G ports.
Basically, I am trying to improve the performance of my P4080DS system, as there was some loss in the packets sent out of the board and this is not reflected anywhere in DPA counters or BMI counters.Even the tx errors in ifconfig show as 0, but the there is packet loss.
I am trying to figure out on how to change the PCD policy, so that it may probably improve the performance of sending packets without any loss.
Could you please suggest what could be the better policy and RCW for my system.
The board details are:
       P4080DS with Freescale sch-24801 REV A2 extension board connected to Slot #3
root@p4080ds:/usr/etc# cat /root/SOURCE_THIS
cd /usr/etc
reflector
root@p4080ds:/usr/etc# reflector
Found /fsl,dpaa/dpa-fman0-oh@1, Tx Channel = 46, FMAN = 0, Port ID = 1
Found /fsl,dpaa/ethernet@4, Tx Channel = 40, FMAN = 0, Port ID = 9
Found /fsl,dpaa/ethernet@7, Tx Channel = 63, FMAN = 1, Port ID = 3
Found /fsl,dpaa/ethernet@8, Tx Channel = 64, FMAN = 1, Port ID = 4
Found /fsl,dpaa/ethernet@9, Tx Channel = 60, FMAN = 1, Port ID = 9
Configuring for 4 network interfaces
Allocated DMA region size 0x1000000
cpu hotplug daemon not running: No such file or directory
reflector starting
Released 0 bufs to BPID 7
Released 0 bufs to BPID 8
Released 4096 bufs to BPID 9
Data stashing: Enabled
Thread uid:0 alive (on cpu 1)
reflector> ifconfig
..........  USDPAA Configuration  ..........
Network interfaces: 4
+ Fman 0, MAC 9 (10G);
        mac_addr: 00:04:9f:03:56:e1
        tx_channel_id: 0x40
        fqid_rx_hash:
                (PCD: start 0x900, count 32)
        fqid_rx_def: 0x5b
        fqid_rx_err: 0x5a
        fqid_tx_err: 0x7a
        fqid_tx_confirm: 0x7b
        buffer pool: (bpid=7, count=0 size=192, addr=0xdeadbeef)
        buffer pool: (bpid=8, count=0 size=576, addr=0xabbaf00d)
        buffer pool: (bpid=9, count=0 size=1728, addr=0xfeedabba)
+ Fman 1, MAC 3 (1G);
        mac_addr: 00:04:9f:03:56:e4
        tx_channel_id: 0x63
        fqid_rx_hash:
                (PCD: start 0xc00, count 32)
        fqid_rx_def: 0x61
        fqid_rx_err: 0x60
        fqid_tx_err: 0x80
        fqid_tx_confirm: 0x81
+ Fman 1, MAC 4 (1G);
        mac_addr: 00:04:9f:03:56:e5
        tx_channel_id: 0x64
        fqid_rx_hash:
                (PCD: start 0xd00, count 32)
        fqid_rx_def: 0x63
        fqid_rx_err: 0x62
        fqid_tx_err: 0x82
        fqid_tx_confirm: 0x83
+ Fman 1, MAC 9 (10G);
        mac_addr: 00:04:9f:03:56:e6
        tx_channel_id: 0x60
        fqid_rx_hash:
                (PCD: start 0xf00, count 32)
        fqid_rx_def: 0x67
        fqid_rx_err: 0x66
        fqid_tx_err: 0x86
        fqid_tx_confirm: 0x87
reflector>
reflector>
reflector>
reflector> quit
reflector stopping
Thread uid:0 killed (cpu 1)
root@p4080ds:/usr/etc# ifconfig
fm1-gb1   Link encap:Ethernet  HWaddr 00:04:9f:03:56:de
          inet addr:10.10.10.142  Bcast:0.0.0.0  Mask:255.255.255.0
          inet6 addr: fe80::204:9fff:fe03:56de/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4639 errors:0 dropped:0 overruns:0 frame:0
          TX packets:22885 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1030610 (1006.4 KiB)  TX bytes:26409671 (25.1 MiB)
          Memory:fe4e2000-fe4e2fff
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:38 errors:0 dropped:0 overruns:0 frame:0
          TX packets:38 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:2592 (2.5 KiB)  TX bytes:2592 (2.5 KiB)
root@p4080ds:/usr/etc# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: fm1-gb1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:04:9f:03:56:de brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.142/24 scope global fm1-gb1
    inet6 fe80::204:9fff:fe03:56de/64 scope link
3: tunl0: <NOARP> mtu 0 qdisc noop state DOWN group default
    link/ipip 0.0.0.0 brd 0.0.0.0
4: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
Sharath Chandra
3,884件の閲覧回数
sharathchandra
Hi Yiping,
It is working now, after I started using the default images from SDK1.7.
Earlier I was using dtb for USDPAA only,but even then issue was coming, the only difference was the change in kernel image related to kernel timer interrupt frequency.
I dont know why this should cause any issue with USDPAA but after I revert back to the default pre-built binaries, it is working.
Thanks for the help,
Sharath Chandra
