P5020 Absolute Maximum Operating Temperature
2,992 次查看
ethan135
Does NXP have any limits or data on the absolute maximum operating temperature of the P5020 processor?
The hardware manual states the maximum recommended operating temperature is +105C but what happens if this is exceeded while operating but below the non-operational temperature maximum (+150C) for a period of less than a week?
4 回复数
2,924 次查看
Hector_Villarruel
Hello Ethan,
Thank you so much for provide the entire part number,
I have checked with the team and please note if you do not follow the specs and requirements that has been tested and supported located on the data sheet of the QorIQ P5020/P5010 Data
Sheet,
In the long run you may damage the device of find unexpected errors.
Have a Wonderful day.
Hector Villarruel.
2,935 次查看
Hector_Villarruel
Hello Ethan,
Could you please be so kind to provide the entire part number nomenclature of the device?
We will be waiting for your kind update,
Hector Villarruel.
2,931 次查看
ethan135
Hi Hector,
Thanks for taking a look at this.  The entire NXP part number is: P5020NXE7QMB
Ethan
2,952 次查看
Hector_Villarruel
Hello Ethan,
This post is to inform you that we are still working to answer your questions about this case.
I will keep you informed.
BR,
Hector
