P1011 maximum clock input
1,935 次查看
danielminors
I cannot find any detail on the datasheet regarding the tolerance of the 100MHz maximum clock input for the P1011 processor. What is the maximum clock PPM that can be used when supplied with a 100MHz source?
1,879 次查看
yipingwang
The 100MHz SYSCLK supports spread spectrum on P1011
So essentially there is no ppm restriction on this clock.
1,908 次查看
yipingwang
Confirming with the AE team.
