P1010 UTAP connect failed:secure debug
pzc
II'm debugging a custom P1010 board, and due to flashing an incorrect BootLoader, the board can't connect to UTAP, encountering secure debug issues. I've searched through numerous existing threads, including this one "USB TAP: secure debug challenge/Response"  (My problem is the same with this one, but it didn't entirely resolve the issue). Hence, I'm still facing this problem. Can anyone assist me? Thanks a lot!
SebastianG
Hello @pzc,
I will attend you on the case #00619579
pzc
I've solved my problem, I don't need help now.Thanks!
