I was trying to create 8 partition by editing the hv.dts file. But currently after boot up into Hypervisor, it shows the error of "Could not load the image". As shown below,
[0] =======================================
[0] Freescale Hypervisor 1.3-009
[0] Hypervisor command line: config-addr=0xfe8900000 console=ttyS0,115200
[0] malloc_init: using 14100 KiB at 0x7f130150 - 0x7fef4fff
[0] malloc_init: using 1060 KiB at 0x7fef6000 - 0x7fffefff
[0] dt_read_aliases: Alias pci1 points to non-existent /pcie@ffe201000
[0] read_pma: phys-mem-area lnx1_pma is not a power of two
[6] read_pma: phys-mem-area lnx7_pma is not a power of two
[3] read_pma: phys-mem-area lnx4_pma is not a power of two
[7] read_pma: phys-mem-area lnx8_pma is not a power of two
[1] read_pma: phys-mem-area lnx2_pma is not a power of two
[2] read_pma: phys-mem-area lnx3_pma is not a power of two
[5] read_pma: phys-mem-area lnx6_pma is not a power of two
[4] read_pma: phys-mem-area lnx5_pma is not a power of two
[0] assign_callback: device buffer-pool@7 in buffer-pool@7 not found
[0] assign_callback: device buffer-pool@8 in buffer-pool@8 not found
[0] assign_callback: device buffer-pool@9 in buffer-pool@9 not found
[0] assign_callback: device buffer-pool@16 in buffer-pool@16 not found
[0] assign_callback: device buffer-pool@17 in buffer-pool@17 not found
[0] assign_callback: device /fsl,dpaa/ethernet@16 in dpa-ethernet@16 not found
[0] assign_callback: device /fsl,dpaa/dpa-fman0-oh@1 in dpa-fman0-oh@1 not found
[1] get_rpn: mem-range has unmapped guest address at 0x0.
[0] get_rpn: mem-range has unmapped guest address at 0x0.
[0] hv_pamu_config_liodn: liodn 146 or device in use
[0] configure_liodn: config of liodn failed (rc=-259)
[0] Loading uImage from 0xfe9300000 to 0x1300000
[2] Loading uImage from 0xfe9300000 to 0x1300000
[3] Loading uImage from 0xfe9300000 to 0x1300000
[1] Loading uImage from 0xfe9300000 to 0x1300000
[2] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[5] Loading uImage from 0xfe9300000 to 0x1300000
[2] load_uimage: cannot copy
[1] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[3] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[5] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[6] Loading uImage from 0xfe9300000 to 0x1300000
[1] load_uimage: cannot copy
[3] load_uimage: cannot copy
[4] Loading uImage from 0xfe9300000 to 0x1300000
[6] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[0] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[3] guest p4-linux: could not load image
[5] load_uimage: cannot copy
[7] Loading uImage from 0xfe9300000 to 0x1300000
[1] guest p2-linux: could not load image
[2] guest p3-linux: could not load image
[4] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[6] load_uimage: cannot copy
[0] load_uimage: cannot copy
[3] loading binary image from 0xfe8020000 to 0
[5] guest p6-linux: could not load image
[6] guest p7-linux: could not load image
[1] loading binary image from 0xfe8020000 to 0
[7] copy_phys_to_gphys: cannot map dest 1300000, 0 bytes
[0] guest p1-linux: could not load image
[3] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[2] loading binary image from 0xfe8020000 to 0
[1] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[6] loading binary image from 0xfe8020000 to 0
[7] load_uimage: cannot copy
[4] load_uimage: cannot copy
[7] guest p8-linux: could not load image
[2] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[4] guest p5-linux: could not load image
[5] loading binary image from 0xfe8020000 to 0
[6] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[0] loading binary image from 0xfe8020000 to 0
[5] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[0] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[4] loading binary image from 0xfe8020000 to 0
[4] copy_phys_to_gphys: cannot map dest 0, 0 bytes
[7] loading binary image from 0xfe8020000 to 0
[7] copy_phys_to_gphys: cannot map dest 0, 0 bytes
HV>
I was following this document Section 4.2.1.6. Hypervisor Deployment
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/QorIQ-SDK-1.6-IC-RevB.pdf
Here are the command I used, are they correct?
.2.1.6 Hypervisor Deployment
4.2.1.6.1 Introduction
At the U-Boot prompt, set the environment:
=>setenv bootargs config-addr=0xfe8900000 console=ttyS0,115200
=>setenv bootcmd 'bootm 0xfe8700000 - 0xfe8800000'
=>saveenv
4.2.1.6.2
switch to bank 4(assume alt bank)
1. Program kernel to flashtftp 1000000 /tftpboot/p4080ds/u-boot-P4080DS-2014.01+fslgit-r0.bin
=>tftp 1000000 /tftpboot/p4080ds/uImage
=>erase e8020000 +$filesize
=>cp.b 1000000 e8020000 $filesize
2. Program ramdisk filesystem to Flash
=>tftp 1000000 /tftpboot/p4080ds/fsl-image-core-p4080ds.tar.gz
=>erase e9300000 +$filesize
=>cp.b 1000000 e9300000 $filesize
3. Program Hypervisor image to Flash
=>tftp 1000000 /tftpboot/p4080ds/hv/hv.uImage
=>erase e8700000 +$filesize
=>cp.b 1000000 e8700000 $filesize
4. Program Kernel dtb to flash
=>tftp 1000000 /tftpboot/yocto/boot/p4080ds-usdpaa.dtb
=>erase e8800000 +$filesize
=>cp.b 1000000 e8800000 $filesize
5. Program HV dtb to Flash
=>tftp 1000000 /tftpboot/p4080ds/hv-cfg/R_PPSXX_0xe/hv-2p-lnx-lnx.dtb
=>erase e8900000 +$filesize
=>cp.b 1000000 e8900000 $filesize
6. Booting up DS board
=>boot
Is there anything I did wrong? Did I transfer the wrong file?
Peter
