The size of my DDR chip is 4GB, can I only assign 1GB memory address to it?
Min Zhao
解決済! 解決策の投稿を見る。
Yes, you have to specify:
the base address that you want from Local Access Window Base Address Register
the size (1 GB in your case) from the Local Access Window Attributes Register - it has the SIZE field in it, bits 26-31
regards,
Catalin
regards,
Catalin
