pn7161 initial firmware
291 次查看
user_ahmed
HI
I'm trying to connect pn7161 with esp.
but I'm failed
my question is any initial firmware i must burn in begging or dirictly i can connect IC with any another board
5 回复数
277 次查看
KaiLi
Hello @user_ahmed
PN7160/1 is a frond-end product, which cannot  work alone, must work together with Host, like MCU. So, you mentioned "esp", is it a type of Host? if so, esp can communicate with PN7161 via I2C or SPI.
Also, you bought the IC, which has default FW, when it worked with the Host, its FW can be updated to the latest version.
275 次查看
user_ahmed
any library available to communicate between host and ic ?
265 次查看
KaiLi
Hello @user_ahmed
It's recommended that you can refer to SW6705 - PN7160 NXP-NCI MCUXpresso Example Project, which is based on MCU projects.
Please log in Plug-n-Play NFC Frontend with Integrated Firmware | NXP Semiconductors to download it.
260 次查看
user_ahmed
PN7161 does not have working firmware in RAM. it tries to upload firmware, but in my setup the firmware file is missing. so i need your help  find/download the correct firmware array from NXP’s package where the basic file in package that i need thanks
242 次查看
KaiLi
