ncp_device example code not working on FRMD-RW612 board
1,389 次查看
LOKENDERVASHIST
Hello Everyone,
I wanted to run ncp_device example code on FRDM-RW612 board which is not working.
IDE used : MCUXpresso IDE v24.12
SDK used : LOKENDERVASHIST_0-1747890582736.png
When flashed the code on FRMD-RW612 got a hard fault error as shown below:
Can anyone help me with this issue debugging ?
1,331 次查看
LOKENDERVASHIST
Hello Shaun ,
Please find attached .axf file
1,147 次查看
shaun_wu
Hello @LOKENDERVASHIST
Sorry for late reply. It works on my board. Could you try unlock your FRDM board?
Disconnect and connect your board with the ISP button pressed.
Best Regards
Shaun
1,343 次查看
shaun_wu
Hello
Could you share built .axf or .bin file to us?
Best Regards
Shaun
