facing syntax error while signing image on hsm
1,336件の閲覧回数
pawar_123_y
I am signing imx-boot-imx8qxprom5620a1-2G.bin-flash using./cst -i u-boot.csf -o out.bin command facing
error: line 40: syntax error
Undefined error
csf file:
[Header]
Version = 4.1
#Security Configuration = Open
Hash Algorithm = SHA256
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
Engine = Any
[Install SRK]
File ="../../crts/SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
File ="../../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate CSF]
Engine = DCP
[Unlock]
Engine = CAAM
Features = RNG
[Install Key]
# Key slot index used to authenticate the key to be installed
Verification index = 0
# Key to install
Target index = 2
file ="../../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate Data]
Verification index = 2
Engine = DCP
Blocks = 0x1200000 0x0 0x1000 “./imx-boot-imx8qxprom5620a1-2G.bin-flash”
Please guide me on this error.
1,324件の閲覧回数
Zhiming_Liu
check error: line 40: syntax error, you could input error config.
